Please recommend a good source for a replacement battery and maybe an appropriate battery (2004 R1150R).
thanks!
Battery and source
Re: Battery and source
Odyssey PC-680 is one of the choices but there are many others, you can try:
http://www.ImpactBattery.com/BMW
http://www.batteryweb.com/motorcycle-batteries.cfm
and
http://www.beemerboneyard.com
Good luck
and
Good luck
++ on the Odyssey PC-680
The Kurch Man
Need to take a look at the TruGel batteries. 100% Gel - most batteries are AGM and call themselves Gel. You can drill a hole in the side and nothing comes out of a TruGel - plus they carry a 2 year warranty. Make sure to take a look at them before you buy anything.
Dennis
2004 R1150R
2004 R1150R
Sabertooth37
The Kurch Man wrote:Need to take a look at the TruGel batteries. 100% Gel - most batteries are AGM and call themselves Gel. You can drill a hole in the side and nothing comes out of a TruGel - plus they carry a 2 year warranty. Make sure to take a look at them before you buy anything.
Sounds good. Do you have a source and model # for the TruGel battery for the R1150R.
Thanks!
The Kurch Man
Check with your local dealer - they can get them from Tucker Rocky Distributing. They are new to the market just this year and from what I have heard, they are quite the thing. I believe the model for the r1150r is an mg51913 but your dealer can verify.
Dennis
2004 R1150R
2004 R1150R
The Kurch Man
Dennis
2004 R1150R
2004 R1150R
Sabertooth37
Thanks for the information!
