It came with the rear mounting bits (rubber bumpers and screws) and a spacer for the front, but I had to order the front mounting bracket and screws from Max's. When the skid plate arrived, it turned out (as I had feared) that the GS has a completely different center stand and so that part of the set wouldn't work (anyone have an R1200GS and want a center stand plate cheap?).
On Friday I got the mounting bits from Max's and after a bit of fussing, got it mounted to the bike. Looked really great. Then, as I was showing it to my appreciative wife, she had to ask "Will it fit with the center stand?" - oops, the tail of the skid plate hit the center stand preventing full deployment. Back to the drawing board. Took it off and after measuring a few times, figured I could get away with removing some small pieces from each side of the back to allow it to clear the stand (more on the right due to the spring). Did that today and SUCCESS! Mounts cleanly and looks like it will add significant protection from my dirt road and whatever else might get kicked up.
The original unit looked like:
and after modification, looked like:
The album has some additional pictures if you are interested.
http://s1026.photobucket.com/albums/y32 ... vt/R1200R/
UPDATE: I heard back from Ernie and it appears that the used skid plate I got was for a 2005 GS and that one is 2" longer than the ones being made now for later bikes, so the surgery I had to do would not apply any more. (Guess you get what you pay for
