Rear Rack for 1997 R1100R
Posted: Fri Feb 13, 2009 7:57 am
by tas
Hello All,
I am looking to fit a rack on my 1100r. It already has a set of BMW panniers fitted with the standard grab rail. Can anyone tell me which rack I should use?
Tas
1100r the only way to fly
Re: Rear Rack for 1997 R1100R
Posted: Fri Feb 20, 2009 2:14 pm
by macinnr
Tas.. I have the BMW rack which was an option on the r1100r (standard on mine). It's a silver coloured thing with a reasonable size plate on it an grab handles integrated into it. I should think it will set you back £150 from a BMW dealer. If you want it to attach a top box, e.g Givi, then it may be worth buying the Givi monorack as it should be stronger - I cracked the plate on my BMW one after I fitted a Givi top box and the plate is £60 to replace on its own. Not sure of the Givi rack will fit with your BMW panniers and pannier arms though...
Posted: Wed Feb 25, 2009 11:31 am
by tas
thanks for the information.
the idea that the bmw rack cracked is a little bit of a concern because the givi rack is not as cosmetically pleasing.
in the meantime i have been looking at a touratech solution. again, straying from the standard bmw looks, but more practical with the top loading panniers.
Posted: Sun Mar 01, 2009 5:53 am
by Commainz
Take a look at Hepco&Becker's rear rack, which is, as of my opinion, a very useful alternative to the original racks and where you can mount easily a lot of things...
It is available for a lot of bikes, including your one (special fit).
Regards
Posted: Thu Mar 12, 2009 4:26 pm
by daytonaredeye
Tas,
Sorry to be late to the party but below are links to photos of my bike with the GIVI rear rack - both with and without the monocase mounted. I've also posted the link to a pic with my bike totally loaded for long distance travel.
Hope these help.
Curt
http://www.bikepics.com/pictures/1391772/
http://www.bikepics.com/pictures/1439588/
http://www.bikepics.com/pictures/1439592/
http://www.bikepics.com/pictures/1418744/
Posted: Mon Nov 23, 2009 2:17 am
by myr1100r
I also have GIVI rack for my rear top case.
Posted: Wed Nov 25, 2009 7:07 am
by miker1100r
I have been pleased with my Hepco-Becker rack. I bought a Hepco-Becker 40L Journey topcase to mount on it as well. I did have to remove the charcoal cannister to install the rack. The case has been great. I installed an additional LED brakelight on it as well.
