Probably so.. It stands to reason that in great dual sport country like AZ, the roadster would not be in great demand, whereas the GS would be a big seller. Practically speaking, the RR can follow a GS most places, and I can testify to that fact, having done so on my RR. The RR would probably sell well in the north end of the state where the great mountain roads are. The only real disadvantages are the smaller diameter tires and that the RR cannot turn off the antilock brakes which can cause interesting times on a ride.
Our local dealership has had a number of RR's that have moved quickly, as have most other models including LT's. There is, or was, a Black with pinstripe 07 available in the Shreveport dealership several weeks ago you might check out if you are in a hurry.
Here is my take on the F800ST:
F800ST
Type
Water cooled twin cylinder 4 stroke
Displacement
798 cc
Bore X Stroke
82 mm x 75. mm
Horsepower
85 bhp @ 8000 rpm
Torque
63 lb/ft @ 5800 rpm
Valve Gear
DOHC, chain-driven with bucket tappets
No of cylinders
Two
Compression Ratio
12.0 :1
Engine Management
BMW Engine Controller - BMS K
Valves per Cylinder
4-Four
Valves
2 x 32 mm mm intake / 2 x 27,5 mm mm exhaust
This bike is a bright blue metallic, and quite striking. As noted it is a liquid cooled engine, so no cylinders hanging out in the wind.
The seating position is almost identical to the stock setup of the R1200R: slightly forward leaning and bar height that caused me to find some bar risers/setbacks. This bike caused me the exact pressure feeling in my wrists and lower back, so were I to purchase one, that would be an immediate modification of absolute necessity.
The seat height is very similar to the R1200R in that I can flatfoot this bike.
This bike's instrument cluster is very familiar to me: It is identical to the cluster on the R1200R, so I feel right at home. The display cycles just like my R12R, so nothing to learn now!
Pressing the starter button in the familiar BMW control setup, the engine designed by Austria's Rotax springs to life sounding much different than the Boxer engines, kinda like a Japanese bike. So I am ready to go: Very first impression is how fast the inline twin spools up. It is an absolute necessity to use the wrist down position on the throttle unless you want to float the front end!
Acceleration is nice, though compared to the Boxer's 109 HP and higher torque output, it is not quite as firm a push in the butt !. Roll-on in 6th gear is acceptable for acceleration, but again, if you have been on a Boxer engine machine, it is not as hard an acceleration without downshift to get the torque you need. Shifting is smooth and precise in all gears.
Running some twisties, I can say that the F800ST is a fine bike for this use. It feels much lighter than the other BMW's and flicks around into turns quite quickly. This will be a great machine as a street fighter, and can play with the crotch rocket crowd. Actually, you think you are on one of the UJM's as the sound and feel is similar.
The rear suspension preload is adjustable via an easily accessible knob on the right side of the bike slightly under the drivers butt, and the fuel tank is located there also, to contribute to mass centralization and the resulting fine handling. (somebody in Germany has been looking at the Erik Buell engineering handbook!) Remember, Rotax supplies the new liquid cooled engine for Buell too. Hmmmm...
Up to highway speed on I-10, nice fast acceleration to merge at Hwy 73 for a fast scoot back to Siegen. High speed cruise is nice and stable, at one point doing a pass up to 90 to get away from a tailgating joe sixpack idiot. Did that easily after a quick downshift to 5 and rolling on the gas. One minor annoyance I did notice is that the inline twin is buzzy. You can feel the high frequency buzz in your seat, which is not objectionable, but you can REALLY feel it in the handlebars; this will put your hands numb quickly. Obvious mandatory immediate upgrade is to purchase some heavy Throttlemeister's which will take care of that problem as it did in the R1200R, as well as give a cruise control feature the bike needs.
The seat is nice, although I only road it for about an hour, so I have no real opinion on the long haul rides.
The computer was showing consistent 60-65 MPG readout at this point, so the bike should get great gas mileage after a proper run-in period for the engine. At one point going south on Airline Hwy, the computer at 50 mph was showing 72 mpg!
Back into the lot at Hebert's and coffee, just in time to visit with some folks in looking at several of the consignment bikes, and pick up my R1200R for the run home.
Impressions:
The F800ST is a great bike properly positioned in the middle of the lineup of BMW Bikes. It is quite obviously aimed squarely at the Japanese bikes of Honda, Yamaha and Suzuki, and will be an definite asset to the BMW lineup. It is available with side cases, that give flexibility of doing some cruising with luggage.
It would make a very nice upgrade bike from someone who is just starting out riding, and wants something a little bit peppier than a thumper around 500cc. It is light enough to handle well as a step up bike, without the awsome power of a litre class machine. It is a very fine motorcycle.
