Replacement Antenna Key Ring...Failure??
parkec
Triple Lifer
Post by parkec »
Something odd started this week as I prepare for my 6000 mile check tomorrow 11/14....When I go to start the bike nothing, [-o< no start energizing sequence, no nothing except the click of turning my key to the right position. Upon retry (Turning key) I get power on the second or third try. :-k
Bad ignition switch?
Bad key ring? NOTE>>>Already had the recall performed.
IBA #50026
ka5ysy
Triple Lifer
Re: Replacement Antenna Key Ring...Failure??
Post by ka5ysy »
Try the battery; a lot of us have been having instant battery death without warning. If you have the original Exide in the bike, that is probably what happened.
MSF #127350 NAUI #36288
2011 RT
parkec
Triple Lifer
Post by parkec »
Update..
Had my 6000 mile check done (Will repeat part of this post over at 6000 mile thread..cost comparisons).Spent $400 for the check, and time for the ignition issue, and a new $150 battery..dino oil.
btw...I had cooked my original battery by leaving my lights on at Starbucks a month ago for two hours, and had replaced it with the similarly shaped :mrgreen: ybst ...whatever battery.
The dealer was unable to duplicate my problem, but the Bike tosssed up a numerous codes.... so I figured why not. and bought a new battery.
NOTE THE DEALER HAS REPLACED THE ANENNA RING MULTIPLE TIMES ON A COUPLE OF BIKES.. one bike is in it's SIXTH ring.. :smt030 No problems in a little over amonth for him. Dealer claims there are Replacement Ring generations.....
IBA #50026
parkec
Triple Lifer
Post by parkec »
NOT THE ANSWER
Was out on a 215 mile 10 stop tour d florida (on the coming home leg...70-80mph @69degrees (BMW) into a 13-17mph head wind + gust per accuweater. Comiog home was really fun..sorry about my cee baily comments and the "why didn't you just buy an RT) :mrgreen: .* 80mph was a bitch!!!!!!... HEATED VESTS ROCK...............BUT>>>problem still exists.. did notice if the bike did not energize, and I reversed the key the bike started 1st time. :-k
Going to continue to test.. matter of fact I'm going to order a second key in th A.M.
This sucks.
IBA #50026
WILDPIG
Post by WILDPIG »
YOU MUST DEMAND THE DEALER INSTALL THE LATEST REPLACEMENT ANTENNA RING WHICH ENDS IN THE PART NUMBER ...... 247. TO DATE THERE HAS NOT BEEN A FAILURE WITH THE .....247 ANTENNA RING WHICH WAS PUT OUT AS THE LATEST AN GREATEST REVISION PART IN MARCH/APRIL OF 2008....... I CALLED BERLIN AN BASICALLY RAISED SOUTHERN BOY HELL TO BMW AN THAT WAS THE RESPONSE.............................. LATER I HAD TO OPPORTUNITY TO TELL CORPORATE BMW ZACTLY WHAT I THOUGHT OF EXIDE BATTERY AN THE COVER UP THE FACTORY HAS ENGAGED REF THE FAILURE RATE OF 2006-2008 R1200R'S TOTIN THOSE DAM ROADSIDE FAILURE'S WAITIN TO HAPPEN........... BMW WONT TO HAPPY WITH ME WHEN I FINISHED,,, GUESS WHAT -- I WONT TO HAPPY WITH THEM EITHER... NOW FOR 1 MORE LIL TIDBIT---- ME AN CORBIN BEEN GOIN ROUND AN ROUND AN I AM VERRRRRRRRR UNHAPPY CONCERNING THIER SEAT...... UPDATES TO FOLLOW
WILDPIG
Post by WILDPIG »
IN FACT-- YOU MIGHT WANA ASK THE DEALER WHY IN THE HELL HE AINT INSTALLED THE .....247 ANTENNA RING , I MEAN ITS COMMON KNOWLEDGE TO EVERY DEALER IN THE USA TO USE THAT LATEST ISSUE----- ESPCIALLY SINCE NO REPORTED FAILURES WITH THE NEW ONE. LOOKS TO ME THAT DEALER NEEDS TO HEAR SOME IN YER FACE CONVERSATION FROM YOU CONCERNING THIS.
The symptoms of the ring failure are rather obvious - EWS! staring at you from the instrument cluster display. If you're not seeing this - the ring ain't the problem.
Given your symptoms I'd be checking for a pinched/damaged wire going up to the ignition switch. Someone else (I think here - if not - on the MOA site) had identical problems after he had the ring antenna replaced. The first dealer couldn't duplicate it - or find it. The second dealer he went to had it happen in the shop and was able to track it down to a loose connection to the ignition switch, undoubtably done when the antenna ring replacement was done.
YMMV and I don't YELL.
WILDPIG wrote:ME AN CORBIN BEEN GOIN ROUND AN ROUND AN I AM VERRRRRRRRR UNHAPPY CONCERNING THIER SEAT...... UPDATES TO FOLLOW
Somehow, I thought that might be the result. It's "custom" right? No return, no refund, it's yours.
Meanwhile - update on the Sargent seat. Still liking it - I don't notice it when I'm on the bike, which is the best thing I can say about a seat - it don't make my ass hurt. That's a very good thing.
WILDPIG
Post by WILDPIG »
WELL CORBIN IS BREAKIN IT OFF IN ME-- TOTAL LACK OF CONCERN TO THE CUSTOMER-- THEYRE REFUSING TO GIMME MIKE CORBIN-- THE OWNERS NUMBER OR LET ME TALK TO HIM.. I GUESS EVENTUALLY I'LL GET MY SEAT BACK FROM CALIF. SHOP..... I CAN SAY WITHOUT A DOUBT-- ID NEVER RECOMMEND CORBIN TO ANYONE.NO FOLLOW UPS,, NO RETURN EMAILS, NO RETURN PH CALLS,,, TOTAL LACK OF INTEREST ON THIER PART --BOTH FROM THE FLA STORE WHICH MERELY RETAILS AN THE CALIF STORE WHICH BUILDS THE SEAT...... I THINK PERHAPS A REGISTERED LETTER TO MIKE WILL BE THE NEXT STEP.. AN I WILL BE DOWN IN DAYTONA COME MARCH ,, IT COULD GET VER INTERESTIN ME ON THIER SHOW ROOM FLOOR CAUSIN A SCENE................
mogu83
Post by mogu83 »
Wildpig -- what caused the change from this ?:
Re: THE CORBIN SAGA CONTINUES
by WILDPIG on Thu Oct 23, 2008 6:43 am
OK-- HERES THE UPDATE-- CORBIN IMMEDATEATELY JUMPED ON THE SEAT AN SHAVED IT DOWN,, FINE TUNED IT TWICE WITH ME ON IT. GAVE ME A CLAIM NUMBER AN SENT FED EX MAN TO THE HOUSE AFTER DAYTONA// KEY WEST TRIP TO RE-SEND BACK TO FACTORY---------- AINT COSTIN ME A PENNY.. I'M NOW VERY HAPPY WITH SEAT-- CORBIN GETS A NUMBA 1.
Private messageAIM
parkec
Triple Lifer
Post by parkec »
back to my subject......."Replacement Antenna Key Ring...Failure??" hopefully not yours to come.
EWS Clarification...
Not getting an EWS code...No codes, no lights, no life, no nothing..only a click of the key turning/locking into the ignition "On" position.
Luckly on the second or third try the ignition energizes. and Varoom. :D
btw...problem developed 1500-2000 miles and 3-4 months after ring replacement.
IBA #50026
WILDPIG
Post by WILDPIG »
PARTEC-- PRETTY MUCH SOUNDS LIKE BATTERY IGNITON ISSUE AN NOT AN EWS/ANTENNA RING FAILURE-- I'M VER CERTAIN BASED ON YOUR LAST POST IT IS NOT AN ANTENNA RING ISSUE. NOW BOUT THE CORBIN SEAT-- THEY JUMPED RIGHT ON IT WHEN I WAS IN FLA STORE CUZ I WAS DOWN FOR FALL RALLY AT DAYTONA,, AFTER THE KEYS AN THE GLADES I SENT THEM THE SEAT PER AGREEMENT TO CALIF STORE WHEN ALL DEFECTS HAHAHAHA ARE CORRECTED,, AN BASED ON WHAT I SAW IN THE FLA STORE THEY GET A TON O DEFECTS TO CORRECT. WELL ALL THAT WAS OVER 4 WEEKS AGO,, SEAT HAS BEEN SENT TO CALIF STORE AN ZERO ZILCH NADA NOTTIN FROM THE CORBIN PEOPLE...... ONLY REASON I KNOW ITS AT THE CALIF STORE IT THAT UPS SENT ME A CONFORMATION...... SO HERES THE DEAL IN NEXT 10 MINUTES IM CALLIN JR AT THE FLA STORE, WHO HAS FACILATATED THE ENTIRE PROCESS AN IM GONNA SEE IF I CANT MOTIVATE HIM TO DO THE RIGHT THANG... BUT I WILL SAY THIS-- AFTER 5 SEATS I VE PURCHASED FROM CORBIN, VISITING THE STORE 25 YRS IN A ROW ONCE EACH YR DAYTONA RALLY,, I WILL NEVER AGAIN SPEND A PENNY ON CORBIN OR RECOMMEND EM..............................
motoracer8
Post by motoracer8 »
I have a Ducati Multistrada, and it uses a simular system of key reconition. With each machine comes a code card, and you use the throttle to input the code should something hapen to the antitheft system. I have never had to use this process, but I know one who has, it over rides the system and lets you start the engine.
Ken G.
motoracer8 wrote:I have a Ducati Multistrada, and it uses a simular system of key reconition. With each machine comes a code card, and you use the throttle to input the code should something hapen to the antitheft system. I have never had to use this process, but I know one who has, it over rides the system and lets you start the engine.
Ken G.
Sounds like Ducait was reading the BMW forums (I'd made that suggestion..) :lol:
socalrob
Post by socalrob »
Ducati has been doing that since day one with their chipped key bikes. BMW needs to read the Ducati forums. ;)
Phillo
Post by Phillo »
This EWS failure seems to be a fairly common problem, I have been without my own bike 2007 R1200R since 29th September ( see Firing on One ) and have had two loan bikes from the agents in the meantime the current one being a 2008 GS and yesterday it died on me - EWS failure so they are collecting it today and hopefully letting me have another loaner until the repairs to mine are completed.
R50/R69S/R50S/R65LS/XT660R-2007 R1200R- Now 2009 R1200GS - 69 YEARS YOUNG STILL GOING STRONG
parkec
Triple Lifer
Re: Replacement Antenna Key Ring...Failure 2 ??
Post by parkec »
12/10/2008 UPDATE.
Dealer consulting w/ BMW North America....BMW Mechanic in Daytona at BMW sponsered Electrics Clinic...might have an answer, might not.
Most likely. I will need to leave bike w/ dealer so they can replicate the problem ( Turn key and nothing, no systems energizing, no NOTHING...just the click of key locking into th on position ) . Once replicated BMW will authorize the replacement of the replacement Antenna Ring.....while under going disection the system will be examined from the battery cables to the ignition switch. Note Battery was replaced a month ago as a first correction attemp. Bike stays on Battery Tender when not in use. Bike used almost dailey for local commutes of 2 to 10 miles oneway...say 200-300 miles a week. Don't stone me for this tid bit. #-o ..but our home does not have a garage/carport..(lost in a lot split years ago..new garage on post recession list) .Bike stays covered. location Florida. Weather related??
Interesting and troubling..last couple of days no problems.. keep looking for trends..none found to date.
But you know what.. I like really this bike!! :D
IBA #50026
parkec
Triple Lifer
Post by parkec »
1/1/2009 UPDATE.
Still not been to the dealer to have her dissected. NO starting issues since last post.except...probably road the bike 6 out of every 7 days. Mostly commuting..about 8 miles each way. stop and go. Weather ..dry 58-78F
Took here out for a quick 170mile round tripper on Monday. Later that day I took a little ride to the postoffice...
I went to leave the post ofice turned my key from locked to off...and the ignition ENERGIZED :-k didn't think anything about it and I pushed the start button and VAROOM #-o then she died.
Turned the key one more click to on. energized and VAROOM off I went. hmmmmmmmmmmmmmmm.
IBA #50026
That is rather a large clue the problem lies in the ignition switch, not the EWS antenna.
Shortpower
Post by Shortpower »
I had a similar thing happen to me. I turned the key and nothing came on. Since I hadden't anything else to do, I switched the kill switch off and on and the bike returned to normal. Try it next time--its worth a shot.
