R1200R Windscreen on R1100R?
Posted: Fri Sep 19, 2008 5:49 am
by dbuffington
Hi Folks!
At the BMW website, you can see a small plexiglas windscreen for the current R1200R.
Anyone know if it can be fitted to the R1100R? Or if some other similarly sized windscreen is available?
Thanks!
Dave
Re: R1200R Windscreen on R1100R?
Posted: Fri Sep 19, 2008 8:10 am
by babulin2002
very good question, i've been also wondering what kind of windscreens (non r1100r specific) can be mounted on the r1100r.
Posted: Fri Sep 19, 2008 8:50 am
by Arbee
Not sure about the R1200R but i fitted the R1150R Sportster Screen
Relatively straight forward... but... this model has the Tacho & Clock
on the outer which the brackets do not allow straight forward assembly
with the 2 longer bolts only, the instrument brackets must be trimmed,
where the bolts mount underneath, other than that it looks cool and rides
well, takes a lot of the wind off my shoulders which makes a relaxing ride.
I loctited the screws on the windscreen as well.
Posted: Sat Oct 25, 2008 5:12 am
by macinnr
I also fitted an r1150r speedster screen to my r1100r. Just had to source longer two longer M8 bolts and it fitted straight on. A cheaper alternative are the £30 screens from Hein Gerrick. I had one also and it worked just as well - didn't look as good.
