First impressions and path forward - II
Posted: Sun Sep 07, 2008 9:05 pm
So, I put the first 1000 miles on my new to me 1150 (there was 9500 on the clock when I got it). Still like it a lot!
12K service is not due yet, but I since I have gotten no service records from the previous owner - I decided to do the basic maintenance anyway.
Changed the oil, checked the dyno belt, fixed the gaps on the spark plugs, adjusted the valves (right intakes really needed adjustment - I could noticeably move the arm even with the feeler gauges in), got rid of CCP. Now surging is barely noticeable at around 2500RPM, but I can live with it (I don't know what fixed it though - removal of the CCP or proper plug gaps). There is still clicking I can hear when the engine is at idle and at low RPM. I am sure valves are adjusted right - is this noise to be expected (I am not familiar with this engine)?
Next I need to adjust the idle RPM (now it is around 800). I understand that I need this differential manometer thingy to do it properly, or can it be done without it? Throttle bodies sync will be done when I get the gadget.
Now Carbon canister. What do people do with it? Should it follow the yellow CCP cube? If yes - what is the proper way of removing it and routing the hoses? (Or is it just "disconnect the hoses, detach the canister and throw it away"?)
I have so many questions because I don't even have a manual yet - it is still in the mail.
Thanks...
Thanks...
