Castrol GTX
Castrol GTX
Post by riceburner »
Ie - regular "good quality" car oil. Is there a good reason why I shouldn't use it in my Rockster??
I can buy it in my local small supermarket (tescos), which makes it a DAMNED site easier to get hold of than Castrol GP* (which I normally prefer).
*currently masquerading as "Actevo 4T" I think...
FloridaBeakster
Re: Castrol GTX
Post by FloridaBeakster »
No reason not to use it. Even less if you ignore the whole dino versus synthetic debate. With our dry plate clutches, there is no concern using automotive spec oils in these bikes.
-Mike
'02 R1150R
'88 R100RS
KeithC
Re: Castrol GTX
Post by KeithC »
I've been using Castrol GTX 20W50 since I bought my '04 R with 2K miles on it. It now has 10K. No problems (although, 10K miles is not many). I change my oil every 3K miles. Oil consumption is now down to almost nothing (i.e., ~ 1/2 quart per 2.5K miles), so I may soon go to synthetic, and increase the change interval.
Keith
jarobi
Donating Member #: 644
Re: Castrol GTX
Post by jarobi »
A bud has an R1150GS with 120K. 100K has been with castrol 20W-50.
MikeCam
Centurion Moderator!
Donating Member #: 100
Re: Castrol GTX
Post by MikeCam »
Automotive oils in the SJ/SL/SM range use fewer additives. Those in the SG/SH range, which is BMW's recommended spec, have a more robust additive package. Independent guys who have credibility have experimented and reported that any good quality motor oil of the proper weight, when changed regularly for the conditions used, is sufficient.
Re: Castrol GTX
I run GTX 20/50 and have since 03. Put 42K on an 03 (which I know is not many) and about 7K so far on an 04. Still using Castrol (with a non BMW filter) No problems and I don't expect any. (except for possibly clutch splines)! :lol:
Too bad good oil won't fix that.
Sunbeemer
Donating Member #: 593
Re: Castrol GTX
Post by Sunbeemer »
I've been changing oil with it at least every 3k for 24k miles. Only known issue is when it gets real hot (which it does here this time of year) it thins out and may not provide the extreme protection of the higher zinc-phosphate concentrations found in the SG/SH oil. And since its dino oil, it is more susceptible to thermal degradation at high temperature than synthetic oil, so I often change it after 1800 miles during summers.
MartinW
Re: Castrol GTX
Post by MartinW »
You might want to consider the Castrol Act-EVO GP 4T.
It's now the recommended oil according to my local BMW dealer.
Of course, you don't want to pay BMW prices but you can get it here for a reasonable (by UK standards) price:
http://www.racelubricants.co.uk/product ... 2&P_ID=408
Life Member #551
02 Blue BMW R1150R non-ABS
Re: Castrol GTX
MikeCam wrote:No reason not to use it.
that's what I was wondering - the BMW manual recommends SF-SG-SH, but the car oils all seem to be SL or above.
Re: Castrol GTX
MartinW wrote:You might want to consider the Castrol Act-EVO GP 4T.
That's the stuff I have already been useing - it's just hard to get hold of.
bransan
Re: Castrol GTX
Post by bransan »
I've been running Castrol GTX in all My Beemers for the last 25 years. I have obtained 400,000+ mi on My 83' 320i, and over 300,000 on a 84 533i. My 73' Bavaria was born and raised on Castrol, and lived in My shop for 10 years and 100k miles with no issues, and I told the new owner all of that too.My r65 loved it for 60k , and I have just ove 34k on My 04' R1150R running GTX 20/50. I broke a rocker arm in My 320i at 350k and upon disassembly of the motor found the main journal bearings still within spec. I am sold on this oil and will use it for years to come. As far as the thermal breakdown issue, I think Castrol has excellent characteristics to maintain viscosity.
This is definatley a quality oil, IMO.
Keep Your Stick On the Ice.
Listen to Me at kaxe.org
