First 1200 Miles
Posted: Fri Jul 25, 2008 10:47 am
Hello all,
First time posting on this site...formerly a K-Bike guy (well...had an RT in the mix along the way too...). Anyway, I picked up a 2008 R1200R last Thursday the 17th. I've ridden it about 1200 miles so far and here are a few things I've noticed:
1) Great engine...smooth, torquey.
2) To me...seems to be more 'fun factor' than my K1200GT. The GT is a screamer though...that's for sure...
3) Like the 'no-nonsense' looks.
4) After coming off years of full-fared bikes...I will need to get used to a bit more 'breeze'.
5) Seat...jury is still out on that. My arse was getting a bit sore at the end of 450 miles yesterday.
I do have a few questions to ask the experienced:
1) I have consumed about a 1/2 quart of oil during the 1200 miles. I know, I know...search oil topics...I did and noticed that oil useage is all over the board. I will monitor as the engine 'matures.' Anyway, just wanted to confirm that this is normal.
2) When in 6th gear running the engine around the 4000 rmp mark, there is a noticeable pulsing hum/slight vibration coming from the engine (at least I think it is coming from the engine). The hum frequency is about every second. When I first noticed, I though it was the road surface, but I then heard it many times during the 1200 miles and on different road surfaces.
3) Brake fluid seepage. I had the brake line recall taken care of before I picked-up the bike. I rode the bike for a day and stopped back at the shop the next day to pick up an accessory. I mentioned that the front brakes felt squishy (in the lever). The tech. bled the lines, etc. and the brakes felt great. I then rode the bike for about 250 miles. The next time I rode I noticed fluid seepage around the bleeder nipple at the front brake lever. I wiped it up, tried to tighten the nipple (did not move). The seepage continued for about 100 miles then stopped. I then looked at the rear brake reservoir and saw seepage. The reservoir cap was a tiny bit loose, so I cinched it up. No fluid seepage for 700 or so miles. I looked at the rear reservoir this morning and it looks like a bit of fluid has made its way out. The rear brake pedal does seem to have a bit too much throw in it (squishy). Hmmmm...Thoughts?? I do have my 600 mile service scheduled for next week (dealer does not want 600 service done until 1000-1200 miles are on the bike). Of course, I will have them address the seepage issue. Just thought I would ping all of you to see if you've had the same issue. Brake line recall related or perhaps a 'redo' of the fluid/bleeding is all that needs to be done.
4) Floating front discs: this is simply a curiosity question. My other 3 BMW's did not have floating discs. Why does the R1200R have floating discs? When I first rode the bike and hit bumps I thought..."ummmm...what is all that clanking up front." Anyway...just wondering.
Whew...lots of words here.
