Second Annual Mississippi Mud Run
Posted: Mon Jun 09, 2008 3:12 pm
Well, it's in the history books now... read about it here.
Welcome to r1150r.net, your largest online source for all things R-R!
https://r1150r.org/board/
Wow, sounds like you had a worse time than me... or should I say better time...iowabeakster wrote:Ves,
What a crapper. Sounds like you had an even worse trip home than I did. Although mine was no picnic.
Every thing he says is true, except for my name, which is Kirk. It's ok Ves, half the people I've ever met call me Kurt. I've gotten used to it, and never really cared. I need to use my handy rhyme more often...
starts with a K
ends the same way
Ves is not exaggerating...if you ride with those boys from Milwaukee, expect to ride fast, extremely fast. We asked John, the guy from Texas, if he wanted to join us. He said, "No, you guys ride way to fast for me." Turns out, he was right, we ended blasting past him so fast he seemed to be stationary. My bike has never worked that hard as it did on Saturday. It probably won't again, unless there is a next year.
Yes it is true, I made the retarded decision to leave the rain-gear at the hotel. Doh! I also managed to drop the bike in front of new acquaintances. (I need an emoticon for kicking myself) Even with all of that...it was awesome.
My ride home, as mentioned, was no picnic. Starting off, the sun was shining and I had a blast. I rode some more great roads working my way south. Occassionally, I ran into roads covered with rocks and mud washed down the hills. There was a couple roads closed due to flash flooding. I was forced to turn around and try a different road several times to get across some rivers and creeks. Other than that, I was having a great time. I got too hot and took off the rain gear. This brought Murphy's Law into effect.
Quickly the clouds moved in and it started raining. I put the rain gear back on. I rode east and took highway 35 until the first bridge into Iowa. I braved rain, wind, thunder and lightning the rest of the way home. I tried a road that is supposed to be scenic...on this day, it was all water and mud. It was a bad day for scenery. There were flooded rivers, farms and towns the whole way home. I was only 30 miles away from home and had to stop because I was nearly blown off the road. I waited and rested underneath an elevated section of I-380 as tornado warning sirens were blowing in Cedar Rapids.
I made it home, and shortly after, Amy arrived home and made me a Margarita. Man did I need that.
Now I sit here waiting for the water to over-top the dam...and wondering how high the water is going to go.
