Good Morning All,
I have a need to remove the catbox from my bike. I almost started to do so awhile back, but waved off when I saw the O2 sensor waiting harmlessly up front. Any experiences worth reporting? FWIW, I do have a manual, etc. Just wanted to ask BEFORE I do something bad (read "bad" as EXPENSIVE)
Thanks.
O2 Sensor Removal, How much drama?
- Bruce_Almighty
Bruce
BMW MOA #130127
2006 K1200LT
2005 R1150R
BMW MOA #130127
2006 K1200LT
2005 R1150R
- geothepencil
I did this last week. Drop the cat carefully and the wires on the O2 sensor are long enough to allow the unit to ALmost reach the floor. The O2 sensor is a bear to get off on real tight plus many hot cold cycles. I just put a wrench on it and supported the cat on the center stand and tapped the wrench with a BFHammer. It then had a few turns of the O2 swensor and then spun the cat. I don't think you can just twist the O2 without harming the wires, but the cat can spin. Reassembly is the opposite.
Michael
MG 78 LeMans
78 R100S
MG 78 LeMans
78 R100S
- Bruce_Almighty
