Recently the heated grips on my 2000 R1100RT have only been working on the low setting. Thinking that the problem is related to the switch, I have pulled the switch. The switch has 3 wires, black, orange and green with a black stripe. In one position I have continuity between the green with black stripe and the orange and in the other position I have continuity between the green with black stripe and the black wire. Am I checking this correctly? I am thinking from these results that the switch is fine. Any suggestions on trouble shooting this problem. Thanks in advance.
Steve
Heated grip switch trouble shooting?
Steve Kolenda
the switch seems ok
G/day the wiring diagram seems to surport your findings. Both the orange & the black are conected to the green/blue when "Hi" is selected. Power comes down the green/blue, is VDC present in the cther two when "Hi" is on? good luck
