Wayne, don't know. I'll toss the IR thermometer in the tank bag.. should be doing some riding this weekend, at least a few hundred miles, so I'll try to check. It would be interesting data to have.waynemathews wrote:I'd add the caution to use your surface scan thermometer as soon as possible after stopping as the tread surface cools more rapidly than the rubber deeper in the tire. Do you have any data that correlates inner air temperature to rubber temperature? I'm sure that if you ride long enough they equilibrate, but how long does it take?
A 20% rule comes closer to what I've observed with radials. The SportRider recommendation was close, but I wonder how it will hold up when the air and road-surface temperatures climb. I'll have to keep an eye on that also.I think that it is interesting that 10-20 rule and the SportRider recommendation actually correlate pretty well for tires in the 30 - 40 lb inflation range.
It would be really handy if I had a voice activated recorder so I could take readings of pressure/temperature while riding and save them. I'll have to look into that also..
