Just installed the JTD134 exhaust.
Used a metal filler 1.25 mm thick in between the RR exhaust tube and the short pipe.
The real gap between them is 1.8 mm, preferred to use a smaller filler otherwise it would have probably be impossible to install it.
The JTD134 external diameter is 51.5 mm
The JTD134 internal diameter ( I filed the border imperfections away ) is 47.62 mm
The RR exhaust outer diameter is 44 mm.
I fabricated that insert using Home Depot parts that are sold to hold together wooden parts used for roofing. In this case it was a straight ruler of something like 12 inches long; I cut it in the correct lenght, that is Pi times 44 = 138 mm and gave it a cylindrical shape as needed to fit around the RR exhaust pipe.
After that I pushed the JTD134 into the RR exhaust, with the filler already in place. I bent the border of the filler a bit inwards so it would not obstruct the JTD134 when being placed in, that bent part was like the 5mm nearer to the incoming JTD134.
I pushed the JTD134 up until it covered a bit more than half the insert. At that point it was already hard to push it in any further.
Then I used
three metallic pieces, like 3 inches long each I cut from a " 3/4" x 10' Galvanized Hanger Strap" part # 33923 at the Home Depot. This thing is used to support pipes hanging from roofs and attached on walls.
I placed these
three metallic pieces uniformly separated, flat against the exhaust the filler and the JTD134 diameters, then used three metal worm clamps on top of them. One bitting completely over the JTD134, one other over the filler insert, and the last bitting exclusively over the RR pipe. The three of them bitting over the three
metallic pieces.
I did not need to make any slots on the JTD134. I chose not to because with this technique it was not needed and because the JTD134 metal is to thick and wouldn't bend nicely I believe, also the difference in external RR diameter and internal JTD134 being 3.6 mm if not soehow filled would have surely generated a leak through the slots..., I believe.
These metal parts cost at the HD were less than 10$ total. And only a small part of them was used.
The sound is great.
I do travel long with my RR, so I'll let you know how it works noise wise in long tips soon.
Well this are my two cents.
I have a question for you all now..., I'm considering to get a Left case from a R1150RT, now that the big exhaust is not there anymore. I'm sure the two top supports of this case match the ones present on the RR,
my question is if the bottom support matches with the position offered on the RR ( that is close to the pillion's left foot )????
The code of the RT left 32 lt case is 46 54 2 317 611.
The code of the RR left 25 lt case is 46 54 2 317 031.
Thanks a lot for any info on this.
Eduardo.
