It's a Torx-25, had to dig one out today to install a heated clothing pigtail on a friend's R1200GS..lewellen wrote:You'll need a Philips head to remove the negative battery lead, and a Star (Torx) wrench to remove the positive battery lead. Or at least I needed one when I installed a fused pigtail, just last night. I think it was a T-25 but am not 100% sure. The positive screw is actually a little post with the star cutout on top.
Charging tender trouble
Re: Charging tender trouble
The 2009 bikes must be different. Both of my terminal screws are phillips. Then again, my turn signal wire couplers are the new sealed version versus the spade type. I know this because I just ordered L.E.D blinkers and checked to see if I needed the wiring harness.deilenberger wrote:
Paul
2009 R1200R
2009 R1200R
