Repair and maintenance manuals
Beancounter
Post by Beancounter »
Does anyone know where I can get hold of a soft copy of a Rockster repair and maintenance manual, something similar to Haynes?
Cheers,
Cam
I've got the CD with the factory workshop manual in it.
Will get you a copy made up. (it's NOT a haynes manual, but does include some instruction.)
Also look up the "Advice" pdf that's available on the web - actually hoot it - I've got that too and will stick it on the CD.
Probably get it done sometime this week? When do you need it?
Beancounter
riceburner wrote: Probably get it done sometime this week? When do you need it?
As soon as please dude! :)
taosports wrote:
...<links>...
Thanks. :)
jeffbowman
Post by jeffbowman »
I've got the Clymer BMW R850, R1100, R1150 and R1200C (1993-2005) Service, Repair and Maintenance Manual. Just shy of 800 pages. I've used it for a dozen different projects and it has been thorough and accurate for my '04 Rockster.
The Clymer manual number is M503-3 and an online search should find multiple sources.
Ughh. You clearly stated softcopy. This thing is a brick. Maybe the info will be helpful for others, perhaps as a doorstop. :P
Jeff Bowman
Blue on Black '04 Rock
ibux
Post by ibux »
I'm thinking of buying either the Haynes or the Clymer repair manual:
http://www.clymer.com/Book.aspx?bid=843 ... +1993-2005
or
http://www.haynes.com/products/sfID1/8/ ... ductID/328
Any suggestions to which of these I should choose? Or is the one just as good as the other?
ibux
'08 Titan Silver Metallic / Magma Red R1200S
