After riding for an hour or so, my feet felt warmer than a typical ride with the can on. Am I imagining things or can that be possible?
Anyone else have the same thing?
By the way, the rear rim/tire look excellent now that you can see it!
Yep. Remove the catalytic converter and replace it with a Remus Y-pipe and you're good to go. Otherwise that cat puts out some serious heat.riceburner wrote:The cat puts out a lot of heat with or without the can.
