The tire dilemma
mcollect
The tire dilemma
Post by mcollect »
Oh no another tire thread :shock:
Michlin's new tire Pilot road 2s aren't due in country for months and my RR needs tires now. Conti Road attacks or Michlin Pilot roads are my top choices. Any differences, I ride in the hills and twisties 90% of the time.
Michael
Michael
MG 78 LeMans
2002 R1150R
78 R100S
wbrisett
Post by wbrisett »
I put a set of the Avon Storms on my RT and they beat every other tire I've had on my bike from handling standpoint. I don't know how they will fare in the mileage wear department, but they handle like no other tire I've owned. You may want to consder these for your R as well.
Mine: 2009 R1200RT, 2007 Buell Ulysses, 2009 Buell 1125CR
Wife's: 2004 Red R1150RA
Martyn
Tyre dilemma
Post by Martyn »
wbrisett wrote:I put a set of the Avon Storms on my RT and they beat every other tire I've had on my bike from handling standpoint. I don't know how they will fare in the mileage wear department, but they handle like no other tire I've owned. You may want to consder these for your R as well.
If they are half as good as their predecessor's, the Azaro, they'll wear very well. I am also a fan of the Conti's, but they don't last quite as well as the Avons
Martyn Hillier, Cheltenham, UK.
1979 R100RT, 2013 R1200RT, 2014 R1200R & 2016 R1200RT Iconic.
Pirelli Diablo Strada.
GTR350cc
Post by GTR350cc »
Road Attack = better stick, less life
Pilot Roads = longer life, better wet
I don't mind paying for mistakes. Can I get a discount?
Croc
Post by Croc »
Metzeler Z6. Good in the dry and wet. Long lasting. Done over 10 000miles on current set and still some life. Try to get in as many twisties as possible - including the Alps, Scottish roads and even a track day! :)
Wind in your hair......
Silver '03 ABS (Twin Spark)
ernieshrew
Road Pilot 2
Post by ernieshrew »
I have just fitted Road Pilot 2's onto my R. I have to say without doubt the best Tyres I have ever used. Cant really say anymore than that can I :)
riceburner wrote:Pirelli Diablo Strada.
Will be installing these in 2 weeks. I have seen how they wear,(on other riders Rocksters) and little to NO cupping on the front. :twisted: :D
DJ Downunder
Post by DJ Downunder »
My friend asked about Road Pilot 2's and was told that they are months away.
The next week I had mine fitted in the same place...I don't think they really know..or want to sell old stock.
My PR2's are without a doubt the best tires that I have ever used...next best would be Pirelli Diablo's...IMO...here's a couple of pics of my new PR2's.
wncbmw
Post by wncbmw »
My experience with Avons is that they do OK until they get some miles on them, then the handling gets a little squirrelly.
I am on my 3rd set of Pirelli Stradas and they do well wet or dry and handle well right to the end. Mileage is about the same as I got from the Avons and Z6s.
Vann - Lifer No. 295
rbertalotto
Post by rbertalotto »
Had a set of Z6 on my VFR, third set on three different bikes (VFR, R1150Rs, K1200RS). Good tires. Replaced them with Avon Storms on the VFR....AMAZING tire! What a difference. I can't wait for my Pilots to wear out on the Rockster to replace them with Storms......
RoyB
Dartmouth, MA
04 Rockster ABS
http://www.rvbprecision.com
rbertalotto wrote:Had a set of Z6 on my VFR, third set on three different bikes (VFR, R1150Rs, K1200RS). Good tires. Replaced them with Avon Storms on the VFR....AMAZING tire! What a difference. I can't wait for my Pilots to wear out on the Rockster to replace them with Storms......
The ads from Avon look great. What about long term wear?
baltm604
Post by baltm604 »
I am probably going to try something different after the avons. the front tire definitely starts riding bumpy after about 70% wear.
Maybe the strada's next?
cworley5150
Location: Princeton (not NJ but in the other armpit) WV
Post by cworley5150 »
I can give a little input here. I have about 3k miles on a set of Storms on the Rockster. I really, really like the way that the tires handle, turn in and just generally feel. The only fly in the ointment is wear. The rear is just about to the wear bars already. Front however still looks like new. I may get another 500 miles from the rear. I usually get about 4.5k miles on a rear and 6-7k on a front.
I've never tried Avon tires before and from what I hear, those that have used both the Storms and the Azaros seem to prefer the Azaros. I think I may mount a rear Azaro instead of the Storm in order to use up the remaining life of the front tire.
For reference, I keep the pressures at 36psi front and 40-41psi rear. I ride solo with luggage about half of the time and do a pretty even mix of commuting and twisties. I also hit the twisties pretty agressicely. No chicken strips on the rear and about 1/4 inch on the front. By the way, the front Storm wraps around farther than any tire I have ever used. I usually get my front to the edge or very close to the edge on most tires. Not on the Storm though. Maybe I'm just not trying hard enough!
If I could get 4.5-5k out of a rear with these tires, I would use them again. Doesn't look like that will happen so Pilot Roads are next for me.
No matter where you go, there you are.
Boxers Rule! Umm. . . the bikes, not the underwear.
Rog(UK) - Yorkshire Dales
Post by Rog(UK) - Yorkshire Dales »
Yes; I think I will be trying Pilot Roads next change because of the dual compound construction. My Continental Road Attacks seem to be more worn than I would expect them to be after 3000 miles - I don't think they will go beyond 5000 miles.
CW. Do you ride heavily loaded most of the time? The only reason I ask is that I have a feeling that 40-41 psi is a little on the high side and will result in more central wear.
Ride safely,
Rog
2004 R1150R Rockster
1978 Moto Guzzi V1000 Convert
cworley5150
Rog(UK) - Yorkshire Dales wrote: CW. Do you ride heavily loaded most of the time? The only reason I ask is that I have a feeling that 40-41 psi is a little on the high side and will result in more central wear.
Ride safely,
Rog
I suppose majority of my miles are loaded and riding twisties. Still Commute a lot though. One thing I failed to mention in my post above was that the rear Storm, although wearing quickly, is wearing very evenly. Just beginning to slightly square off. The tires still handle as well as the day they were mounted. Like I said, if they were getting better mileage, I would by another set. Still might.
Here's a thread about the storms on another forum I visit. Take what you will from this thread. Widely varying opinions. (Imagine that!)
http://www.sport-touring.net/forums/ind ... 264.0.html
bikermeow
Post by bikermeow »
The Pilot Road 2CT had a recall, due to some feedback from France. The local dealer in Singapore carried an ad in the press about a recall about a week back.
http://www.recalls.gov.au/view_recall_d ... Auto=14949
Michelin Pilot Power Motorcycle Tyres
Date: 20/06/2007
Supplier Name: Michelin Australia
Product Make:
Product Model:
Target Number:
Model Years From:
Consequences: Such partial loss of the tyre's tread may jeopardise the user's safety in some cases of very high speed usage.
Campaign Number:
VIN Range:
Serial Range:
Product Info: 120/70ZR17 Pilot Power 2CT and 120/70ZR17 Pilot Power. The tyres were produced in France between November 2005 to May 2007 and July 2004 to April 2006 respectively and are marked Made in France and have the Dept. of Transportation tyre identification number (DOT number) which for 120/70ZR17 Pilot Power 2 CT begins with DOT 6UCW 980T and ends with the last four digits 4505 to 1807 and for 120/70ZR17 Pilot Power begins with DOT 6UCW979T and ends with the last four digits 2704 to 1406. The DOT number can be found on sidewall of the tyre just above the wheel rim.
Defect Details: A possible defect in the tread due to a manufacturing irregularity.
Consumer action: Owners of affected tyres can call Michelin's authorised tyre distributors between 9am-5pm AEST, Mon-Fri. Victoria and Queensland (03) 9338 1664, New South Wales and South Australia (02) 4226 2999, Tasmania (03) 6223 4566 and Western Australia (08) 9478 6211 to arrange for a free inspection and free replacement.
Market Coverage: National
Recall Coverage: National
See also:
http://www.wfmynews2.com/business/consu ... ryid=86088
Boris Badenov
Post by Boris Badenov »
bikermeow wrote:The Pilot Road 2CT had a recall, due to some feedback from France. The local dealer in Singapore carried an ad in the press about a recall about a week back.
Date: 20/06/2007
Product Make:
Product Model:
Target Number:
Model Years From:
Campaign Number:
VIN Range:
Serial Range:
See also:
This recall appears to be for Pilot Power.
I did not see Pilot Road 2 mentioned anywhere. What did I miss?
"This plan was fool proof, yes! Idiot proof, no!"
Croc
Post by Croc »
Just a question of how many miles do I have left? 2.5 inch wide flat patch on rear tire. Stock original Dunlap 170. :roll: :lol:
