I ride with earplugs and the stock exhaust and frankly I can just barely hear the engine when I'm cruising. I'm not a speed demon; I rarely exceed the limit by more than 10 MPH, and I'd rather run local (45 MPH) roads than scream down the Interstate. I ride solo with about 50 Lbs. of touring gear. Seems to me that I baby my bike.
I have 34,000 miles on the bike, now, and recently took it back for service before a trip (jumping the gun a bit on the 36,000-mile service, but I wanted to be safe.) I sat down with the service manager and asked him about the repair for "rod knock." He agreed that it could be the small-end bearing -- or the wrist-pin, or the piston bearing, or all three. Or the big-end bearing, which might require a new crankshaft. All apparently very expensive to repair. His suggestion was to sell the bike and get a new one. I told him that the new BMW's dont really interest me; even the 1150 seems like overkill for my style of touring and the F800 is tall and a bit Ricky Racer for my taste. I'd probably change brands if I couldn't keep my RR.
I asked how this could happen, and he suggested running with the oil low, which I'm pretty careful about, or water in the oil, which I don't know how to check, (but I do replace it every 6K miles,) or overheating, which is possible; often I find myself in stop-and-go traffic, and under some circumstances you can't shut down every ten feet. Once at a tunnel exit waiting on an uphill ramp I ran the engine at a crawl for a good fifteen minutes, and I could feel the heat through my Roadcrafter pants (over jeans.) Finally I was able to pull over and shut down for a few minutes, but the catalytic converter was obviously pretty hot.
I guess my questions are these:
Is this reasonable? An '02 RR with 24,000 miles developing rod knock?
Is there anywhere a sound file to tell me what rod knock sounds like so I can know what to listen for?
Is this a repair I could do by myself? I'm not tool-shy, but I don't have a shop or a garage.
Thanks for your advice.
