So ....... What's in yours?
MIXR
Post by MIXR »
I often get asked why I take so much gear on my trips. Why don't I just use the side cases? I also see lots of posts about 'liners' and 'how to store stuff', so while I was checking my bike gear out today, I took some pics of the contents of the side cases. By the way - I have the proper BMW case liners, but find them useless. They take up too much room even when empty!
First up - The cases are almost always on the bike, unless it's just a local run. If I'm travelling overnight, I'll use a large GIVI topcase, or a smaller bag, or a range of other bags for clothes and camping gear. I do lots of long-distance stuff, and it's usually in the more 'remote' parts of the country, so I need to be prepared.
The left case. It's been a full-size case with the can removed for a long, long time.
Open it up and this is what you see. Note the black bag in the lid. More about that later. My wet-weather duds sit rolled up along the bottom of the lid to cushion the big black bag.
The black plastic mesh is to stop stuff falling out - A common problem discussed often here. It's just 'heavy-duty gutter-guard', a thick plastic mesh used to keep leaves out of your house gutters, and cut to fit.
I use the same stuff as an oil cooler protector. Very heavy duty and DOES NOT make the engine run hot. Great for keeping the grass-hoppers and locusts out as well.
This is the case almost empty. The black bag in the lid is for storing a 4.7 litre fuel can. It gets used on the marginal gaps between fuel stops. It's also handy for rescuing others! Normally travels empty. The purple padded bag is a very comprehensive tool kit. Contains a broad range of metric spanners, a set of torx keys, a set of metric keys, a set of torx bits, and a few different pliers and screwdrivers. I have rarely used my tools on my bike. I have often used them on other people's bikes.
The other stuff that came out of the case is as follows - Starting from top left and working clockwise. Toilet roll (naturally), plastic bag with small jumper leads, various zip-ties, and lengths of parachute cord. Then comes a half dozen cylume sticks. The yellow bag has a siphon hose, thin webbing straps in case gear comes loose, electrical wire, tie-wire, and some spare nuts and bolts that I know fit the bike. The long skinny bag has my alternator belt, plus spare bulbs and spark plugs. The larg-ish plastic bag is a well-wrapped half-litre of oil, plus some rags. The open bag to the left has a mini WD40, plus 4 mini tie-downs. Why tie-downs? Well, I've been on three group rides where someone has come off. Easy enough to get a ute (truck) to stop, but each time we had trouble finding enough gear to strap the bike in the tray-bed or trailer. If I break down somewhere and can hitch a lift, I want my bike secured, so I carry my own. Lesson learned - Be prepared.
The right case is marked for carrying my first aid kit so my buddies know where to look if I'm the one who has come off. A simple thing, but often overlooked. Helpful if people are in 'panic mode' and not thinking straight.
Note the plastic mesh divider again. The big red padded bag is my thermal liner for my jacket, plus my heated vest. Keeps it protected.
Note the large size of the first aid kit. It carries stuff specifically for motorcycle crash treatment, and has lots of gear for broken bones, amputated fingers, and gravel-rash. It's been used. More than once. I've improved it each time as I discover important omissions, like larger amounts of sterile water and bigger 'patch' bandages. Carry one, and have the knowledge to be able to use it. I also carry a small towel. Nice for when you find a stream and want a swim.
The rest of the contents from top left and clockwise are: A bag containing my balaclava, a helmet liner, glove liners and cooling scarf. The wrapped box is a mini-air compressor. I have learned not to trust the repair cylinders in really remote places, even though I carry two sets. Next is a bag containing spare sunglasses and glass cleaning materials. Then comes a pack of 'baby-wipes' for those unexpected stop-overs or just to freshen up and remove the sweat on a hot day, and a padded case with two sets of tyre repair gear (two full kits), plus a spare oil filler plug and a few o-rings. Lucky last is a 'personal' kit with map-reading glasses (magnified), some emergency toiletries, spare earplugs, pens, and a few other bits and pieces.
So that's why I always have my sidecases on the bike, and why there is no room for anything else. I can jump on and head of anywhere knowing that all I need is my topcase with spare clothes and toiletries if it's an overnight trip. Otherwise, I'm prepared for anything, and even if I can't fix something myself, there is a fair chance that I've got the bits and tools for someone else who comes along who can fix whatever might be broken. If all else fails - I have my road service card and my credit cards!
Oh - Almost forgot - The underseat area has very large zip-ties for handling broken case attachments, an l.e.d. torch, spare batteries, earplugs, and a few other things, including the service manual and log book.
So what does everyone else carry?
cruiser
Post by cruiser »
Great info and pics MIXR! This information will be very helpful to me when I prepare for my first extended ride next month. :)
I for one would also like to see an underseat pic, showing how you've stowed the equipment you've mentioned there
BTW... your short exhaust extender looks great, but where is the attractive shield that others have retained when making this change?
Mike in Hamburg
2004 black R1150R... and a 1930 Thürmer grand piano - heaven!
MIXR
Post by MIXR »
Not a lot to see underneath the seat, but here it is anyway. The really big zip-ties sit across the side panels. My disc-lock lives under the seats as well. Most stuff is just in the tool pocket under the pillion seat.
I don't use the exhaust shield because it just collects mud and dirt. Not needed. I'd rather be able to get to things as quickly and cleanly as possible. The stubby exhaust has been in place for many years and about 65,000 kms.
I'll break out my tools at some stage at take a pic. I carry a LOT of tools. You never know when they'll be needed, if not for my reliable beast (touch wood), then for whoever (whomever?) is with me. They've been very handy a few times, and I carry some obscure things. I've even rescued a few damsels in distress - In cars!
frbank6
Post by frbank6 »
Mixr,
Very impressive! I didn't realize you could get that much stuff in the cases. I just have the regular lids, but that's no excuse. I would like to point out one thing you might want to think about. If you carry your first aid kit in either of the side cases and then have a fall on that side, you or someone trying to assist will probably not be able to lift the bike to access it. I carry my kit in my tank bag for that reason. Just a thought.
MIXR, I use my top case for rain gear, the sides are for super important things, like BEER! :smt030 :lol:
MIXR
Post by MIXR »
frbank6 - Yeah - Good point, but I don't use a tank bag. I have a couple, but don't like them. They just get in my way! On most of my really big trips, my mate carries his kit as well, so we are covered.
Besides, I don't expect to fall off (Now I've done it - Bad Karma).
wncbmw
Post by wncbmw »
MIXR - interesting thread and pictures. I have been pondering a solution for the 'everything falls out' problem on the side cases. I will have to see if I can find some of that stuff at the hardware store! I would like to invent a shelving/compartment system for the side cases that could be customized for everyones needs. I bet it would sell!
I have been planning on buying extra tools and a first aid kit but haven't yet. Good idea though.
I would not travel without the tank bag however! On a tankbag thread a while back, I took a picture of mine and all the rags, faceshield cleaning stuff, flashlight, maps, writing materials, eyedrops, reading glasses, etc., etc. I carry in mine. It is almost always on the bike!
Vann - Lifer No. 295
triggerfish
Post by triggerfish »
Thank you for posting this MIXR. You are one meticulous dude. Hmmm... you may also want to carry a spare shirt. :wink:
I'll get my own "gutter mesh" as well.. and put a sticker on the lid where I have my first aid kit (it includes a neck brace and a resucitation mask, among other things).
I also carry a triangular warning device like this, in case I get stranded on a busy street. The two pieces can lay flat together to save more space when not in use.
MIXR
Post by MIXR »
I used to carry one of these, but left it out last 'review' because most times you can move the bike well off the road anyway. Different with a car. I do have a flouro vest in the side case as well, under the heated vest bag. Just in case.
R4R&R
Donating Member #: 293
Post by R4R&R »
I carry a few basic tools under the seat, an air compressor under the fuel tank and a basic camping first aid kit at all times. Other items in the cases depends on the trip.
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
sjbmw
Moderator
Donating Member #: 263
Post by sjbmw »
Wow. School's in. Nice job, I got notes to take...my cases explode when I open them...
leoquattro
Post by leoquattro »
Mixr
very useful info and pics! The idea of the plastic mesh is also quite interesting and simple.
Thanks!
ciao
Leoquattro
DJ Downunder
Post by DJ Downunder »
Nice report and great pics MIXR... =D>
But you've just shown the world where you keep your drugs.. :shock: .. :D ..(just kidding)...what is that little brown bag of stuff under your seat?
MIXR
Post by MIXR »
Don't miss a trick do you DJ!
Actually - Nothing as exciting as drugs. I often wake up from a camp and the bike and my gear is covered in dew. So it's just a small 'face washer' (little towel) that sits there in case everything needs a wipe-down to get rid of the water. If not that, then it gets used as something to rest my weary head on when I use my jacket as a pillow on the really light camping trips when I just have a swag on board and no pillow. Softer to lie on towling than on a hard (and bug-covered) jacket.
I took a fold-up pillow with me 'round Aus. Great invention. Compresses into a small package, but gives a better night's sleep when unpacked. Still takes up room though. Hate the blow-up ones.
So .......... It's nothing exciting at all, but it's always handy. I've learned lots of little tricks like that. Could probably write a (short) book!
Buckster
Donating Member #: 543
Post by Buckster »
Thanks for the tips....I'm already making a list for my first out of state trip next month.
You must have some big gutters downunder. I have never seen gutter gaurds that big. Love the idea though. I might use a peice of thin plexi-glass as an alternative.
Thanks again.
Buckster '03R
#543
Trapper
Post by Trapper »
Hey Mixr
I'm seriously impressed - but you forgot this:
http://www.engineeredstone.com/Transoli ... S33223.jpg
Thanks for the tips/pics
Cheers
Trapper
Black '04 R1150R
iowabeakster
Post by iowabeakster »
"More importantly, a towel has immense psychological value. For some reason, if a strag (strag: non-hitch hiker) discovers that a hitch hiker has his towel with him, he will automatically assume that he is also in possession of a toothbrush, face flannel, soap, tin of biscuits, flask, compass, map, ball of string, gnat spray, wet weather gear, space suit etc., etc. Furthermore, the strag will then happily lend the hitch hiker any of these or a dozen other items that the hitch hiker might accidentally have "lost". What the strag will think is that any man who can hitch the length and breadth of the galaxy, rough it, slum it, struggle against terrible odds, win through, and still knows where his towel is is clearly a man to be reckoned with."
quotation from The Hitch Hikers Guide to the Galaxy by Douglas Adams
MIXR
Post by MIXR »
iowa - That is so funny!
I'm going home tonight and throwing out all my towels and other non-critical items! You've ruined me. I'll never be able to pull out a towel on my trip again without thinking of that and laughing! Curse you. :lol:
To be honest, I carry some stuff that I have found (through experience) to be just plain old 'handy to have'. I hate to admit this, but I have ANOTHER small towel that I carry to spread over my GPS and instruments at refuels. That's to save fuel splashes from melting the GPS and the plastic temp guage on the yoke!
Cheers mate. Mick.
As for you Trapper - I don't need one. I use my skid-lid. Doubles as an emergency 'potty' as well. Bugger when you have to stick it back on your head though! :shock:
triggerfish
MIXR wrote:Don't miss a trick do you DJ!
Picture-perfect MIXR! Now is that a harmonica I'm hearing?? :wink:
MIXR
Post by MIXR »
Just so long as it's not a banjo. I stay in some wild places, and I've seen Deliverance!
