Have you ever come home from a ride and plugged in your battery tender? I did last night and was surprised when it took 20 minutes for the flashing green light to come on. What was even more surprising (at least to me) was that 4 hours later the green light hadn't changed from falshing to steady.
Does anyone know if this is normal?
Battery Tender and Flashing Lights
sloopy_farklehump
Re: Battery Tender and Flashing Lights
Your battery could be low..either because it's wearing down, or maybe your alternator is not putting out enuf juice. This of course is given that your charger is OK....sloopy_farklehump wrote:Have you ever come home from a ride and plugged in your battery tender? I did last night and was surprised when it took 20 minutes for the flashing green light to come on. What was even more surprising (at least to me) was that 4 hours later the green light hadn't changed from falshing to steady.
On my 04, bought in May 05, w/ the BMW gel battery and using the official, BMW-approved charger made by Deltran, I plug in the charger after almost every ride.
It normally takes less than 1min for the green to start flashing (indicating at least 80% charge) and it does take a long time to go steady.....>3hrs
BTW...I have a VDO voltmeter connected directly to the battery thru a switch, and after an initial surge to ~14v when getting underway, it settles in the 13.7~13.8v range and stays there.....
j magda
TripleLifer Member 454
Deep in the OH wasteland...
Battery tender
You might also like to check that the socket, assuming you're using the socket on the left side, is OK. My Optimate (battery tender) indicated a problem with the battery, which was only a few weeks old.
Closer inspection showed corrosion inside the socket. Two minutes with switch cleaner & all was well again.
Martyn Hillier, Cheltenham, UK.
1979 R100RT, 2013 R1200RT, 2014 R1200R & 2016 R1200RT Iconic.
