i recently acquired an 04 r1150r. i found that the handlebars were rotated too far down for my liking, so i rotated them up. this brought the grips up higher and in a more comfortable position. however, the problem i now have is that the brake and clutch levers are pointing downward too much.
is there an easy way of rotating the levers up an inch or so?
thanks
rotating handlebars?
godxilla said
It means that you don't have to lift you finger up and over to get on the levers...and if you ever ride standing it's much..much better.
You should try and get used to it...IMO
I also rotated mine forward..and this points my levers down more..and I much prefer it that way..I recently acquired an 04 r1150r. I found that the handlebars were rotated too far down for my liking, so I rotated them up. this brought the grips up higher and in a more comfortable position. however, the problem I now have is that the brake and clutch levers are pointing downward too much.
Is there an easy way of rotating the levers up an inch or so?
Re: rotating handlebars?
Yes, there is. I asked this question a while ago and got the answer. Here's the thread: http://www.r1150r.org/board/viewtopic.p ... highlight=godxilla wrote:i recently acquired an 04 r1150r. i found that the handlebars were rotated too far down for my liking, so i rotated them up. this brought the grips up higher and in a more comfortable position. however, the problem i now have is that the brake and clutch levers are pointing downward too much.
thanks
Rick
2003 R1150R: Silver
Lifetime Member #585
2003 R1150R: Silver
