Wow, what improvements over the 2002 RT that I had! The transmission is great, and the driveability is far improved. The fuel injection is now sorted out. It pulls much harder than the 1150RT as well. I also like the space between the 5th and 6th gear ratio now. The RT had a spread of 1000 rpm from 5th to 6th, making it a true overdrive. This was fine for making long miles on a highway, but resulted in more shifting at speeds under 65 mph. The R1200R spread is only 500 rpm between 5th and 6th, with 6th running at about 75 mph at 4000 rpm. Hard to explain, I guess, but this is much better in real world riding. Being 65 now, I really appreciate the lightness of the R too. The few times my wife will ride with me should be fine. She sat on it with the top case which has the back rest. She said it felt fine for her. We'll see. I plan to run most of the time with just the side cases for my own use.
Hank
Picked it up Sat.
Caol
- Double Lifer
This is going to be such an improvement over my '87 K75T!
I pick mine up at the end of April. (hopefully the weather will cooperate!)
Congrats Hank! (must be nice to be riding at this time year! A person could get jealous!
P.S.
What does it mean when your right wrist starts to twitch???
P.S.
#574
#574
Caol
P.S.
What does it mean when your right wrist starts to twitch??? Wink
Be careful! That's a disease!
What you are feeling is the beginning of the horrible beemeritis.
Next thing, you'll feel your ears twitch and then the grin will split your face and then you're lost....
Don't say you weren't warned.
qgaex
*victim*
P.S.
qgaex
*victim*
Caol
- Double Lifer
qgaex wrote:Caol
P.S.
qgaex
*victim*
As a buddy of mine puts it: "Suffering from PMS (Parked Motorcycle Syndrome)"!!
#574
#574
DRothermel
Hank: Congrats on the new bike. Excellent description of the improvements over the old R and the RT. I agree with all of them and with sixth geared the way it is, there's not much need for a downshift when passing. WOT (wide open throttle)works just fine for most passes.
Richard
BMWMOA, IBA Member
200,000 Mile BMWMOA member
2007 RT. TPM, ESA, ASC
BMWMOA, IBA Member
