Pirelli scorpian sync for the 1150R
mcmarcia
Post by mcmarcia »
I am looking for a more aggressive tire and saw the 160/60/17 snyc will fit the 1150r rear rim. Anyone tried this on the Roadster? I want the best of both worlds, pavement and dirt.
04 BMW R1150RA
92 Yamaha Virago 1100
95 Yamaha Virago 750
Fozzie
Post by Fozzie »
The new Buell Ullysses has special hybrid tyres (road/dirt) made by Dunlop in the same size as that on the Rockster ie 17" rims, 120/70 front, 180/55 rear.
Have a look here: http://mysite.mweb.co.za/residents/clasqm/buell.html
Could be the go.
Argue your limitations and they are.
'05 Rockster
Fozzie
Post by Fozzie »
Here you go:
http://www.dunlopmotorcycle.com/tirecat ... .asp?id=93
A radical new sport radial for the mean streets, with the looks and performance to run anywhere.
Innovative and aggressive tread pattern derived from wet-track road-racing tread design.
Cool-running tread with superior grip characteristics also provides excellent cut and wear resistance.
Front tire incorporates Dunlop's aramid breaker tread reinforcement and radial casing technology to provide excellent steering response and cornering stability.
Rear tire combines Jointless Band (JLB) construction with Dunlop CTCS (Carcass Tension Control System) for enhanced cornering and wear performance, excellent high-speed stability and exceptional tire compliance.
SIZE LOAD/ SPEED INDEX SIDEWALL PART # APPLICABLE RIMS
RECOMMENDED RIM OVERALL DIAMETER OVERALL WIDTH FULL TREAD DEPTH MAXIMUM LOAD @ PSI
D616 Front
120/70ZR17 58W BW 3011-75 3.50 23.62 5.00 6/32 520 @ 42
D616 Rear
180/55ZR17 73W BW 3010-30 5.50 6.00 25.20 7.20 8/32 805 @ 42
BW = Black Sidewall
Do not mix these radials with other radials or non-radials, fit only in pairs.
Note: When new tires are fitted, they should not be subjected to sudden acceleration, hard cornering, maximum power or braking for at least 100 miles. Failure to do so may result in loss of control and serious injury. The 100 mile run-in is required to adjust to the feel of new tires versus the worn tires.
Follow Dunlop Tire Application Guide. For general motorcycle tire service information and important safety guidelines click here. You may also contact Dunlop directly at (800) 845-8378 or fill out our contact form.
Back to High-Performance/Sport
'05 Rockster
