ABS Flush & Fault Code Clearing?
RadicalR1150R
Donating Member #: 960
Post by RadicalR1150R »
I was reading posts over on the "Rockster" side.. I'm doing bleed & flush on R1150R in the next few days..
Do fault codes have to be reset by a dealer after a flush & fill or just when you've had flashing light/problems? fault..
Thanks...
EasyBee
Donating Member #: 61
Re: ABS Flush & Fault Code Clearing?
Post by EasyBee »
In this manual (1.3 Mb), https://www.dropbox.com/s/8tymrxnbw68pk ... 3.pdf?dl=0 they don't.
And if your system was working well before and is working well after the job, why would you?
RadicalR1150R
Exactly, I've never done this my lonesome... The dealer has always performed this service..System has always performed well before service.
I've never been around in the service area "after".. Hence the question? I guess the answer is no, only if you've a fault..
Thank you..still learning..
