Speed bleeder part number
RadicalR1150R
Donating Member #: 960
Post by RadicalR1150R »
Hey.. Anyone know the part # for speed bleeder for 2004 R1150 R BMW calipers. Mines not listed on the site. 02 & 03 are & R1150RS is though..
Whats RS?
Thanks, Steve
sykospain
Re: Speed bleeder part number
Post by sykospain »
It's a Goodridge 10mm by 1.
https://www.ebay.com/itm/Goodridge-Spee ... 2789593930
You should be able to source a few at cheaper prices than Amazon's arm-twisting rate.
Buy several and fit one of each on all the bleed points round the bike - two on the front calipers, one at the rear brake bleed point, and one at the Hydraulic Clutch Bleed point held in the foam sleeve hidden behind the helmet lock. What BMW calls the "Werkstück"
This last one is referred to in this short vodiodi...
https://photos.smugmug.com/photos/i-X2n ... 7K-960.mp4
Bogdan
Post by Bogdan »
As you stated...the info for a 2004 was not on the site. I wrote to them - below is the reply. And yes..those sizes fit. However, I still haven't installed the clutch bleeder. Bogdan
The size(s) for your application is as follows:
Front……SB7100S
Rear…….SB6100
Clutch….SB1010S
When ordering Speed Bleeder, consider also ordering the Bag and Hose Combo. The bag is like an IV bag. It comes with 30 inches of silicone hose. When one end of the hose is attached to the bag and the other end is attached to the Speed Bleeder, it makes the messy job of bleeding brakes neat and clean. The hose and bag are reusable.
Speed Bleeder is also available in 303 Stainless Steel. The stainless steel bleeder will never rust or corrode and is polished to a brilliant gloss for the custom look. To order the stainless steel version go to www.speedbleeder.com click on “Secure Ordering” at the top of the order page you will see a selection “Stainless Steel”. Click on this heading and all the sizes available in stainless steel will drop down.
Thanks,
Whitney
RadicalR1150R
Yes that's the information I got too. The fronts were on back order, Kirby on e bay has them.
Rad...
