Spark Plug Socket?
jonmaddux
Spark Plug Socket?
Post by jonmaddux »
What brand of spark plug socket is everyone using for plug changes? My Craftsman 5/8" will not fit in the tunnel (single spark). Too big OD. Wrench in the toolkit can remove a socket but won't let you use a torque wrench for re-install.
BMWRT.com site search talks about a Kobalt/Lowes socket with thinner walls. Any experience?
Re: Spark Plug Socket?
jonmaddux wrote:What brand of spark plug socket is everyone using for plug changes? My Craftsman 5/8" will not fit in the tunnel (single spark). Too big OD. Wrench in the toolkit can remove a socket but won't let you use a torque wrench for re-install.
you shouldn't need a Torque Wrench - in fact, I'd advise STRONGLY against it.
do the spark plug up by hand/fingers as tight as you can (use the toolkit wrench but without anything to add leverage) - then 1 quarter turn more with the toolkit wrench. That's ALL it needs.
HTH. :)
rdsmith3
Donating Member #: 74
Post by rdsmith3 »
Yes, the spark plug wrench in the tool kit works fine. I think it is the only time I actually used the tool kit for anything.
2002 Atlanta Blue
Lifetime Member #74
jonmaddux
Post by jonmaddux »
riceburner wrote:you shouldn't need a Torque Wrench - in fact, I'd advise STRONGLY against it.
I hear you. But I work in the aviation industry and I don't think I can do that. Must... have... torque wrench.
johnt650
socket
Post by johnt650 »
I made my own using the stock wrench. This was not my original idea, but worked fine. Take a deep socket that you don't need, preferably one that just fits inside the BMW supplied wrench and drill a whole through both the deep socket and the BMW wrench. You can slip a bolt through the two when they are toether and use the ratchet or torque wrench.(be sure the drive side is slighltly protruding. When finished slip the bolt out and you still have a wrench for the toolkit.
Paper
Post by Paper »
Edited, and moved on...
jonmaddux
Post by jonmaddux »
Paper wrote:
What the hell does working on a BMW motorcycle motor have to do with aviation??? :lol: :wink: :lol: 8) :wink: :lol: :smt017 :smt075
The same thing working on a garbage disposal does. If the instructions call out a torque value, use it. Someone came up with that torque value with really good reasoning.
Paper
Post by Paper »
pixrob
BMW has one
Post by pixrob »
There is a BMW socket that is designed for this application....however last time I check it was over $50 or so from BMW of Chicago....
I think I can live quite well without it.
Rob
jonmaddux
Post by jonmaddux »
I ended up buying a $2.97 5/8" Husky brand spark plug socket from Home Depot. Worked like a charm. Smaller OD than Craftsman.
Donating Member #: 217
Post by Photo »
For sparkplugs you can use "Harley-torque"(tm). Just tighten it down 'til it strips...then back it off a quarter-turn. :roll:
The EZ-board poster formerly known as "Photo82"
mnnden
Post by mnnden »
I use the method ricburner discribed, but I will sure be looking over at home dept for that socket jonmaddux suggested, As I do like to torque things to the proper set. Also after a few miles of rideing I like to check and re-tighted as needed, mine have worked loose in the past. Den
We all gave some,
Some gave all.
Anonymous
jm1515
Triple Lifer
Post by jm1515 »
The Kobalt does not work...at least on my 04 TwinSpark.
Neither does the Craftsman, or the ones AutoZone or AdvanceAuto sell. :x
If anyone knows of a thin wall design that actually DOES fit in the cylinder...I'd love to hear abou tit.....
j magda
TripleLifer Member 454
Deep in the OH wasteland...
Xray28
Torque Wrench
Post by Xray28 »
My Grandfather, a master machinist in the late 1800s, through WW II used to say, "Torque until just before it gives!"
All in all I like the method espoused by John650. I can't wait to go out and drill holes in one of my old sockets.
Has anyone gotten the torque meter from Sears? Looks like a cool tool.
Capt. Blackadder
Post by Capt. Blackadder »
jonmaddux wrote:I ended up buying a $2.97 5/8" Husky brand spark plug socket from Home Depot. Worked like a charm. Smaller OD than Craftsman.
Sweet, I'm gonna get that one. Thanks for the tip! :smt023
jonmaddux
Post by jonmaddux »
Try the Husky one from Home Depot. Works on single sparks and a guy at work with a twin spark GS reported it worked on his.
jm1515
Triple Lifer
Post by jm1515 »
Thanx, Maddux...
That was going to be my next destination.
They are building a new HomeDepot in my town, so I will try there ASAP...
j magda
mnnden
Post by mnnden »
Purchased the Homedepot "Husky brand spark plug socket" although it has a smaller OD (13/16) than the craftsman (7/8) it will not work in my "02" Den
We all gave some,
Some gave all.
Anonymous
jonmaddux
Post by jonmaddux »
I will measure mine with a mic when I get home tonight. Maybe the price of the Husky means variation in manufacturing tolerances...
jm1515
Triple Lifer
Post by jm1515 »
Found one!! :D
In case anyone is still interested...
I found a 3/8 drive 5/8" spark plug socket w/ rubber cushion insert at
Tractor Supply Co.
Made by 'Pro-Grade' div of AlliedConsumer. It is their model 13252 and Tractor Supply pn 3800556. 2.99!
Works nicely in both plug tunnels on my 04TwinSpark.
They also have a 1/2 drive.....and for those who may not be able to find a local TS, try
http://www.myTSCstore.com
j magda
