sweatmark wrote:Thanks for posting your progress. Interesting project. A Rockster owner in US (Idaho) did a similar Rockster/GS hydrib a few years back, with some documentation here on the board.
Rockster brake rebuilds: check with riceburner on this forum (and UK-based) who is an expert.
Would be interested in your evaluation of OE Rockster forks supplemented with GS bottom Telelever bracket, as option to your current full GS forks install. I would like to scrambler-ize my Rockster, and prefer the larger GS front wheel/tire for offroad.
You flatter me sir!
Re the Brakes - after about 10 years struggling to keep more than one pair of Tokicos working reliably, I swapped to a 2nd hand pair of Brembos last year. They've gone through a years' commuting through to mid-december (when I took the bike off the road as I bought a car).
I cleaned the brakes of the winter grime a weekend or two ago and where the Tokicos would have had 3 or 4 weather seals blown and over half of the the pistons sticking badly, the Brembos, by contrast, came up beautifully, with NO blown weather seals AT ALL, and ALL pistons moving freely, and releasing off when the hydraulic pressure is release.
HIGHLY RECOMMENDED UPGRADE!!
For Reference - I spoke to Motorworks (UK BMW breaker) and told them WHY I was buying the Brembos, and what I was intending to do - and they followed up on the fiche-research I'd done* and were able to suggest the correct fitment of a pair of R1150RS callipers (IIRC).
Although it might seem that all the R259 BMW models might have the same fitment specs, it appears they are actually different 'enough', that you can't just easily swap callipers between models - the offsets are slightly different I think (so you could fit callipers from a different model and the calliper body would interfere with the disc if the offset is wrong). This is where talking to someone like Motorworks can be very helpful.
* I thought that since the Rockster fork legs and front wheel are (allegedly) the same as the R1100S, that the callipers from the R1100S would be a straight fitment - apparently not!
If you're sticking R-GS wheels into Rockster forks though - you'd very likely have to take some very exacting measurements!!
