My front brakes felt a little mushy lately. Hard braking would pull almost to the grip. It was time anyway for the annual brake fluid replacement. I decided to replace the pads as well. The front brakes seemed to be sticking closed a little and I wanted to give the pistons a good cleaning.
I did the right front ok I think. Disconnected the brake line after extending the pistons and was able to really clean them well. New brake fluid in. On the left side, I left the brake lines attached and cleaned the pistons. They were dirtier than the other side. Bottomed them out, replaced the caliper, and installed the new pads. Bled the lines and pumped up the brakes. Nice solid feel. When I spun the front wheel I noticed they were grabbing a bit so the wheel wouldn't spin completely freely. Took the bike out for a short spin (barely missing a downpour) to test and seat the pads. Brakes felt great. But, they weren't really spinning freely.
I found Cyclerob's awesome write up on brakes in this thread
http://r1150r.org/board/viewtopic.php?f ... 59#p239089
I decided to go back and try his Caliper Piston Push-Back-Push-Out Purge-N-Replace Procedure on the left side. I removed the pads and pulled the caliper off, inserted a large screwdriver to stop the pistons. As I pumped the brakes, I noticed that only one piston would move at a time. I kind of expected all of them to extend together. Not sure if that's normal or not. Cleaned the pistons again (determined my first cleaning could have been better). I pressed the pistons back in with the bleeder open and the brake level pulled back slightly. Went to pump the pistons back out and realized I couldn't do it with the master cover off so I had to replace it and pump. Pistons came out in sequence again. Pressed in again to purge old fluid (which really didn't look bad). Refilled master, cover back on, pumped again. Realized I didn't have my screwdriver in straight and one piston came out way to far. When I was pressing the pistons back in I managed to basically pull the over extended piston completely out spilling fluid on the floor. I carefully pressed it back into place and and bottomed them all out. Reinstalled the caliper, pads, and refilled and bled the line. First attempt was mushy but I bled it again to remove more air I had apparently missed and had a nice solid brake. BUT, it still doesn't spin freely. Gggrrrr.
So, is it normal for the brakes to not release fully with new pads? I'm thinking not.
Is it a big problem that I popped the piston out and reseated it?
I don't have a complete maintenance history on the bike but the guy who had it 2009 to 2013 seemed to get regular maintenance. I bought it 2014 with about 42k on it. Flushed the brakes and clutch shortly after getting it. I don't recall the fluid being overly dirty. Not sure when to consider a complete overhaul of the calipers.
