Front break squeeks when I hold it in. Why?
Torsen
Post by Torsen »
It says squeek-squeek wery fast. It sounds like it follows the vibrations in engin when it idling. Can it be the abs-unit or something? It is only when I hold the break handle in.
peels
Re: Front break squeeks when I hold it in. Why?
Post by peels »
Torsen wrote:It says squeek-squeek wery fast. It sounds like it follows the vibrations in engin when it idling. Can it be the abs-unit or something? It is only when I hold the break handle in.
if youre speaking of the squeal while sitting still, that's the abs system, pump/servo. flush the front circuit out. OR if the unit is bad. replace it. BIG $. or just remove it and have standard brakes. (that was my decision)
or while its moving? that could be a number of things. warped rotor and bad discs. replace them
Torsen
Post by Torsen »
Thanks peels. The rotor and disks is good as new. Take a closer look at abs-unit then.
