swamper wrote:Master cylinder needs to be vented and some fluid drained off if you are pushing the pistons back to install the pads. Common problem on Harleys when guys replace pads.
that would be why the lines "swell" like Ive read about then? back pressure when they're already weak? makes sense. IM guessing its the "crumbled hose" problem for me though... smashed into the banjo. I think tonight Ill take it apart and have a look, and do a flush, just because. then order some parts.
we opened it, and bled them when I changed pads. But...now that I'm thinking about it... When I did the all my maintenance and new tires...when I put the caliper back on, I pried them apart, but did not open it. So, I you just likened me to "harley guys" and I dont like your tone
Didn't have time over the weekend to mess with it, moms day PLUS anniversary...
So, Today, I rode my short commute today very gingerly, on purpose for research. so as not to use the rear brake. Only touched it once, at only 5 mph on a gravelly intersection. When I got to work, the disc was HOT. TOO hot in my opinion.
I am just about convinced that this is ALL of My MPG problem now. Good and bad news, really. But in the end, simple enough. we shall see.
Few quick questions, to make sure I take the right pill and go down the correct rabbithole.
-the correct plan of attack is to completelyreplace the lines, correct? I think I'm going to do the rear before my trip, then tackle the fronts later on. Though they look VERY new. I might go through the previous owners' paperwork and see if it had been done. note: my front wheel spins magnificently free and smooth.
-Is there something simple (read "mega cheap" as I'm pretty tight right now)to try first to alleviate it, or would that be totally futile? Like a complete flush and bleed?
any other advice is greatly appreciated.
thanks again!
