I picked up a used BMW touring windscreen and was anxious to give it a try. Installation was pretty simple - Replace the stock M8x20mm screws with longer versions to account for the thickness of the mounting brackets. My screen didn't come with the longer screws so I guessed on a size (M8x30mm) and grabbed them from the local hardware store. The forward screw on each side came out with some difficulty - fortunately I was able to get the Size 40 Torx bit securely in place. I attributed the difficulty to 10 years of Louisiana humidity and figured that corrosion was the culprit. The back two screws were another story. Due to the bar placement, I couldn't get the Torx bit straight into the head of the screw. The rear RH screw eventually came out using a swivel attachment on my socket wrench (and penetrating oil with lots of patience) but the LH rear screw was a real bugger. After a few slips of the Torx bit, the head was stripped. Here's where I finally got smart.
I removed the bar clamps and gently laid the bar on a thick towel covering the tank. With the screw head cleanly exposed, I drilled a pilot hole and successfully used an extractor to remove the screw. I then ran an M8 tap through the holes to clean the threads before mounting the screen.
I added four stock replacement screws to my next maintenance parts order from Bob's BMW and found the real reason these screws were so stubborn. Each new screw had a tell-tale crimson band in the middle of the threads - Red Loctite! Wow... that explains it.
So my advice to anyone removing these four screws is to first remove your bar and then make sure your Torx bit is securely in the head of each screw. I'm not sure I'd want to try to heat the bolts as the plastic pod hardware behind the bolt head could get damaged.
And one last thing - I realized that the unplated screws procured from my hardware store would eventually rust. While searching through the F650 parts microfiche, I saw that the stock fork tube clamp screws were M8x30mm - a perfect option for my application since they wouldn't corrode. I'll be swapping them out this weekend and using blue Loctite instead of the red.
Happy wrenching!
