Brakes
DAQ421
Brakes
Post by DAQ421 »
I am looking to replace the pads (Front & Rear) and the Rear Rotor (seems the last owner ran the pads down far enough to groove the rotor at some point) on my 04' R1150R..
Is there is better than stock rear rotor?
Are there any pads to avoid?
Thanks..
-Peter
I'd rather get heat rash than road rash. The end..
bransan
Re: Brakes
Post by bransan »
I have been buying brake pads from dennis kirk and have had good luck with them. I cannot recommend an aftermarket rotor, but a factory replacement is not that expensive.
Keep Your Stick On the Ice.
Listen to Me at kaxe.org
DAQ421
Re: Brakes
Post by DAQ421 »
bransan wrote:I have been buying brake pads from dennis kirk and have had good luck with them. I cannot recommend an aftermarket rotor, but a factory replacement is not that expensive.
Thanks I'll check out DK.
