Heated Grips for 96 R1100R?
joelh
Post by joelh »
I would like to add heated grips for my bike and don't want to break the bank. Are there any inexpensive aftermarkets that will work?
Railbender
Donating Member #: 689
Re: Heated Grips for 96 R1100R?
Post by Railbender »
I have Hot Grips, http://www.hotgrips.com/ on two of my bikes. I find that they are warmer than BMW factory grips due to the isolation ribs in the grip that reduce heat loss through the bars. They have several styles and are available with open ends if desired. Plus they are made in the USA!
joelh
Post by joelh »
Just ordered a pair. Is there an easy way to hook up to a switched power source, rather than wiring directly to the battery?
captaincable
Donating Member #: 1050
Post by captaincable »
I looked at those grips yesterday and they say the grips won't work properly with aluminum handle bars. Would like a set myself just wondering if some has used some that work ( 1997 R850R ) without the aluminum sinking the heat from the grips.
Thanks. Mike
Railbender
captaincable wrote:I looked at those grips yesterday and they say the grips won't work properly with aluminum handle bars. Would like a set myself just wondering if some has used some that work ( 1997 R850R ) without the aluminum sinking the heat from the grips.
Thanks. Mike
My initial experience with Hot Grips was on my Ural (steel bars). They worked so well that I replaced the factory heated grips on my R1100R with them. The round portion of the R1100R bars is steel and I have no problem. They aren't quite as warm as the Ural however they are better than the factory heated grips. I used the factory wiring and switch on the R1100R. The BMW wiring is smaller than what I used on the Ural plus the Ural puts out a constant 14.2V compared to 13.7/13.8 for the R1100R so that may account for the different heat output.
Railbender
joelh wrote:Just ordered a pair. Is there an easy way to hook up to a switched power source, rather than wiring directly to the battery?
As I mentioned in my post above I used the existing BMW switch and wiring on my 2000 R1100R. The connection is under the gas tank. I don't know if the '96 wiring harness is the same. I got the small crimp on connectors through the local BMW car dealer (BMW makes cars!) since they are also used on cars and there is no local BMW MC dealer.
captaincable
Thanks Railbender,
I bet my handle bars are the same.
Mike
joelh
Post by joelh »
Where did you read about the aluminum handlebar issue? I had not read that and am hoping it won't be an issue.
Railbender
joelh wrote:Where did you read about the aluminum handlebar issue? I had not read that and am hoping it won't be an issue.
The round portion of the R1100R bars that the grips go on is steel, no problem.
captaincable
Joelh,
I saw it on Hot grips online store under motorcycles second line on page. But as Railbender says if the round part is steel then it won't make a diff. I did notice not to install if you have ThottleMiester throttle lock which I have. Mike
joelh
Post by joelh »
I installed the grips today and they work great. Heat up very quickly. I will have to look into wiring into the existing heated grip plug or running a relay back to the switch, they don't turn off when I shut off the bike and I know that I will eventually forget and leave them on.
