ESA question
jrvip1
ESA question
Post by jrvip1 »
I was under the impression that ESA only adjusted the rear suspension but I read somewhere that it changed both front and rear. What is correct?
The different settings are very subtle but quite noticeable when chucking it around country lanes in sport mode where when coming into contact with uneven surfaces and rutts, it can buck around quite a bit and it can be a challenge sometimes to keep it glued to the road. Adds to the fun factor I suppose :badgrin:
Gravity is your best friend (usually!)
2011 R1200R Classic
2007 Goldwing GL1800
r1200rclassic
Re: ESA question
Post by r1200rclassic »
from what I can see in this diagram, it appears to adjust a lot more than just the rear shock... but I'm not sure.
http://blog.motorcycle.com/wp-content/u ... ighRes.jpg
2012 R12R "Classic" - ESA II, ABS II, ASC, Heated Grips, Computer, Windshield Sport
jrvip1
Re: ESA question
Post by jrvip1 »
This is the schematic I saw as well. However, there is no control valve on the front suspension so it only seems to be on the rear one. All the other devices are just sensors.
2011 R1200R Classic
2wheels
Donating Member #: 547
Re: ESA question
Post by 2wheels »
With ESA you can adjust the preload on the rear suspension(for pillion, luggage, etc). You can only do this with bike stationary and the engine running(you feel the atitude of the machine change).
Also you can adjust the damping on front and rear suspension - comfort, normal and sport. This can be changed on the move and difference is subtle but noticable.
On non ESA machines only rear damping is adjustable.
(not sure but some people refer to 'dampers' as 'shock absorbers').
Catchina
Donating Member #: 998
Re: ESA question
Post by Catchina »
On non ESA bikes both the rear preload and damping are manually adjustable. I don't think there is a front adjustment.
2011 R1200R RED
1996 Virago XV 750
2wheels
Re: ESA question
Post by 2wheels »
The schematic diagram refers to a new 'dynamic' system which senses riding/road conditions and adjusts suspension accordingly. It is not the current ESA system
