Correct me if i am wrong, but it appears that i have the BMW touring screen, so when looking for a taller windshield, i already have the proper brackets needed?
also looking at my seat it appears to be a standard? or is this the low one?
as always thanks all
Most motorcycle problems are caused by the nut that connects handlebars to the saddle. 2009 R12R
If your seat has a little indented detail on the sides right below the seat surface then it is not low, the low seat has no detailing like that that I am aware of. I can't really see it in your picture.
I don't know of a break in period for life, I guess I'll just live it like I stole it.
Member #138
thank you, and yes i have read about don c block
i will get screen first sometime after the summer and see how it works and then see if i need the tilt block.
Don C if you are reading can you pm me the details and the cost so i know in advance
thanks
My original low seat had the indents - and the spare low seat on my shelf still has them. That's not a reliable indicator. If the seating area for the rider is only about 2" high (measured from the bottom of the lip on the side of the seat) and it actually slopes a bit rearwards - you have a low seat.
nylife wrote:thank you, and yes i have read about don c block
thanks
I'd suggest just ordering the block (in the world of farkles - it's cheap..) then order the windsceen one size larger then the vendor spec's - since the block lowers the top edge of the screen (by tipping it back toward the rider.) I know of no one who has gotten the block, or otherwise tilted their screen back who went back to the stock position. It just works better.
