ABSThis is a strange Lights flash at high revs. 1999 r1100r
wells01
Post by wells01 »
This is a strange one. The ABS system works fine unless I rev the engine to 5000rpm or above. At this point the abs lights flash alternately at about 1htz and ABS is disabled. Turning the ignition off and back on resets everything to normal. I have checked the air gaps on the wheel sensors and the brake fluid levels. Any ideas?
Many thanks.
Boxerpunk
Re: ABSThis is a strange Lights flash at high revs. 1999 r1
Post by Boxerpunk »
Charge or replace your battery
Greetz, Erwin
2003 Rockster Full Black
