completed
on the cat (muffler recently removed).
Found a 1-3/4" ID chrome turn down 8" long at Summit Racing
for $13 shipped. Had seen some similar big name brand tips
for as much as over $100 ! They're sure proud of their stuff !
http://www.summitracing.com/parts/JEX-JTD134/
Also found a longer 13" one if anyone would want something
like that, $35.
http://www.jcwhitney.com/13-turned-out- ... zmap=23026
Also found some inexpensive baffles that fit inside pretty reasonable if
someone would happen to want to quiet it down just a mite
http://www.jcwhitney.com/motorcycle-baf ... j1s17.jcwx
http://www.jcwhitney.com/bikers-choice- ... d=c14675j1
On my 8" turn down, there's about 4" max of straight pipe for
installing one of the short baffles.
My turn down is listed as "weld on" but I didn't have to do that.
Cut about 10 slits about 1" lengthwise on the end that fits on the cat,
used a sawzall blade which is wider than a porta band blade to
help reduce the ID enough when squeezed together so it fits snug
over the CC outlet.
Was going to use the existing chrome shield and clamp but when I
looked closer at it I saw that the muffler end of the shield sticks
out a good 1-1/2" from the pipe to cover the forward end of the
muffler, which would look wrong.
I already had the slits cut so I had to use a clamp. I had a nice
stainless heavy duty worm drive clamp so used it. Cut the excess
off and positioned the worm drive behind the pipe & low, about the
5:00 position looking from the rear, so the pipe hides it. Looks OK.
Otherwise would just have drilled one small hole on the bottom and
used a #12 x 1/2" sheet metal screw to hold it on.
Pardon the pics, it was already after dark when I finished.
http://s719.photobucket.com/albums/ww20 ... ust%20Tip/
