iowabeakster wrote:
1--Would you reccommend (or not) the idea of pulling the whole rear tire/FD/paralever/tranny as a single unit and rolling it back?
2--What did you use to make your guide pins?
3--Why does BMW reccommend new bolts (tranny to engine), and why did you reuse yours?
--Answers--
1--Yes. That's the method the BMW manual recommends for a clutch disk replacement, but they are also likely using 3 guys to handle the long, heavy, unbalanced heavy mass. I had other systems that needed attention, like the slave drain addition, FD bearing inspection, throttle box internal cleaning and cleaning/polishing the exhaust system that were made easier because the throttle cables were already disconnected, the wheel was already off and the slave was totally exposed after the swingarm was removed.
2--I used one 8mm diameter x 1.25mm thread x 115mm long cylinder stud and another bolt the same size and length with it's head cut off, both salvaged from a junked engine sometime in the distant past. I save all that good stuff in painted over coffee cans for important needs just like this. You can see the Guide Bolts in the pic below labeled "HomeMade Guide Bolt". They are supposed to go in the same holes at the 10:30 and 5:00 O'Clock positions where the locating dowels are on the motor. Notice the screwdriver slot hacksawed in the stud's end so you can install/remove it.
3--The clutch was being discussed and it's those pressure plate mounting bolts screwed into the flywheel that must be replaced, not the transmission mount bolts. Those pressure plate mount bolts actually are tightened so much (install torque + 32 degrees additional rotation) there's permanent deformation, so they aren't reusable. Since they turn with the motor and must NOT ever loosen up and back out, "special bolts" are required.
Edit: to fix broken link and change photo provider to a better one.
