So, how the heck do you disassemble the headlight on one of these things? I need to change the headlight bulb, but I can't figure out how to get the front off. I see the little set screw at the bottom, and the holes and slot on the underside, but how do these figure into the procedure? Thanks!
-- John
Headlight disassembly on a '99...
Non scholae, sed vitae discimus. -- We learn not for school, but for life.
Re: Headlight disassembly on a '99...
John,
suggest you open the screw and take off the front (which includes the chrome-ring, front glas and reflector). On the rear of the reflector you can see the plug which you need to unplug. Then open the metal clip and remove the bulb. Install a new bulb and reverse the same procedure.
All this should be well described in your manual.
Brgds
Oliver
Brgds
Oliver
