I ran into a problem externalizing the fuel filter according to the plan as put forth in
viewtopic.php?f=2&t=19988&start=0
in the above picture the top most left nipple is marked In
as is the nipple on the left of the filter. So I have the IN s facing each other. Are fuel filters so unidirectional?
Do I have the flow backward on the filter? I have leaks in that limb. The other is unaffected, I think.
The first leak I saw was right at the quick disconnect. I tightened only that clamp and leaks then appeared elsewhere on that limb, or maybe they were there, but they got worse.
Any help appreciated
