I just completed the 'Lillooet Loop' today. For those not in the know, the loop is one of the well known rides in southern B.C., and is popular among bikers in the metro Vancouver area.
I used my vest today, during a good portion of the 670km ride and it worked perfectly. My Venture vest is thin enough to go under my heavier, armoured, Hein Gericke Spader jacket, and since I never wear more than a tee shirt under my jacket, the vest sits close to my body. It has four heat settings and I find that the second lowest setting is more than sufficient to keep me warm. The highest setting is toasty indeed!
Mike
Electric Vest
Re: Electric Vest
2007 Night Black R1200R
And loving it!
And loving it!
- LumpyCam
Re: Electric Vest
And what a beautiful loop it is! A perfect time for a heated jacket with many elevation climbs and drops. Still snow at roadside through the mountains?Zedman wrote:I just completed the 'Lillooet Loop' today.
Re: Electric Vest
Yes, there was still snow on the sides of the road. I got caught in a couple of snow flurries at Duffey Lake itself! But the ride was fantastic and the weather, other than that, was perfect.
Mike
Mike
And loving it!
And loving it!
Re: Electric Vest
Mike- sounds like you had a great ride. Which was the route? 'Lillooet Loop' is new for me- have only lived in vancouver for 1 1/2 yrs.
Stef.
Edit: just seen you email- thanks!
Stef.
"Dream as if you'll live forever. Live as if you'll die today."
R1200R (2010)
R1200R (2010)
- Mollygrubber
Re: Electric Vest
...you're in for a treat... and make sure to do it in both directions (not on the same day unless you're VERY hardcore), the views are equally wonderful both ways.Stef. wrote:Mike- sounds like you had a great ride. Which was the route? 'Lillooet Loop' is new for me- have only lived in vancouver for 1 1/2 yrs.
Stef.
2010 F800GS
Member #741
2010 F800GS
Member #741
Re: Electric Vest
I bought a Keis heated vest for this winter and I've been very pleased with it. It cost £100 UK with a remote switch /temp setting. The temp setting is a sort of timer, the hotter you want it then the shorter the power off period. It's a rather simple design with two heated panels on the front and two on the back. I plug it into the acc socket. It is good value and very effective.
Phil
Phil
Re: Electric Vest
Actually, I rode the 'Loop' in in the Vancouver-Hope-Lytton-Lillooet-Pemberton-Whistler and back to Vancouver direction, (anti-clockwise), which was new for me, but I now prefer it. The RR ate up the roads!
And loving it!
And loving it!
Re: Electric Vest
Moving from a Weider Vest to Gerbings....vest, and pants.
Did you'all go with the portable or fixed mounted Heat Troller?
btw
Where did you mount the Heat Troller?
CP
btw
CP
IBA #50026
IBA #50026
Re: Electric Vest
David Brick
Santa Cruz CA
Santa Cruz CA
