R1200R battery dead
mgdoc8307
R1200R battery dead
Post by mgdoc8307 »
I purchased my new BMW R1200R June 2009. Love the bike-rode 15000 miles and parked it in Feb 2010.I Didn't use a battery tender and therefore when I attempted to start last week -nothing. Took the battery to my dealership in Indian Trail N.C. and was told the battery is "toast-1.6 volts and that they could order a new one for $158 and change. I asked what about the warrenty and they said neither BMW or their dealership will honor any warrenty claims on batteries- I said "WTF and I'll remember you too in the future". Went on Bike Bandit and bought a Yuasa battery for this bike for $88 including shipping. Has anyone else had problems with BMW covering battery claims? I suspect so! :(
websterize
Donating Member #: 710
Re: R1200R battery dead
Post by websterize »
If you call BMW customer service and complain, they will probably quote the manual: ". . . if the battery is not disconnected, the on-board electronics (e.g. clock, etc.) gradually drain the battery. This can cause the battery to run flat. If this happens, warranty claims will not be accepted. If the motorcycle is to be out of use for more than four weeks, disconnect the battery or connect a suitable trickle charger to the battery."
I would still call and try to make a case — the bike is nine months old. The battery warranty is two years.
Dauntless
Post by Dauntless »
Here is another thread on the battery problem: http://www.r1150r.net/board/viewtopic.p ... 67#p166656
Paul
2009 R1200R
mogu83
Post by mogu83 »
When my battery 'went' I called the dealer and he asked if I wanted to come to him for a new one or should he have someone bring it to me. No charge. I think you should think about becoming 'upset'.
Mollygrubber
Donating Member #: 741
Post by Mollygrubber »
So you parked it in February of this year, and it's now March 22. So a little over one month? I'd expect even a BMW battery to start after only one month... maybe I'm being optimistic. I think I would have used a different brand as a replacement, though (Odyssey...).
2010 F800GS
Member #741
I had a battery fail today while riding on my 09' GS, replaced under warranty by a BMW dealer after it was towed.
You could ask 3 dealers what oil to use or tire pressure and get 3 different answers, welcome to BMW dealership spin the wheel for warranty work...
I think it has to do with position of the moon when it comes to warranties.
xprof
Donating Member #: 617
Post by xprof »
Which Odyssey battery are we installing these days, PC535 or PC680?
Mike in SB
2009 R1200R all black
ex1970 BMW R60/5
ex1959 BMW pre-slash R60
ex Matchless G80CS
websterize wrote:If you call BMW customer service and complain, they will probably quote the manual: ". . . if the battery is not disconnected, the on-board electronics (e.g. clock, etc.) gradually drain the battery. This can cause the battery to run flat. If this happens, warranty claims will not be accepted. If the motorcycle is to be out of use for more than four weeks, disconnect the battery or connect a suitable trickle charger to the battery."
Most likely you parked it on the last day of Feb. and it went dead in only 3 weeks. ;)
Liam
Donating Member #: 780
Post by Liam »
xprof wrote:Which Odyssey battery are we installing these days, PC535 or PC680?
Xprof,
I went with the PC535. I think the PC680 is just too large for the R1200R. Even the PC535 isn't a "drop in."
Have a look at my how-to post if you want a handle on how much work is involved.
viewtopic.php?f=20&t=18938
Liam
xprof
Post by xprof »
Thank you, Liam!
Mike in SB
ex1970 BMW R60/5
ex Matchless G80CS
