Torx Wrenches
AncientMariner
Donating Member #: 783
Torx Wrenches
Post by AncientMariner »
I need to get some for the new bike. Should I get regular Torx, or Tamper Proof Torx, which claim that they will work on regular Torx? Can anyone tell me what sizes I'm likely to need? My search on this subject informs me that I don't need any external torx sockets, right? :-k
Bruce
'13 R12R Montego Blue
'95 Mystic Red K75
'94 Black HD FXDS
Re: Torx Wrenches
Visit Harbor Freight. They have a small ratching wrench with security bits - which include the smaller torx sizes for about $3.00. Also look for one of the screwdriver type drivers that use these bits. Then look for the bigger Torx - you need from T15-T50 to cover everything on the bike.
There are a few external torx used (like on the shift lever) - a 12 point wrench in the right size will work on those.
Railbender
Donating Member #: 689
Re: Torx Wrenches
Post by Railbender »
There is no need to get tamper proof Torx bits unless you also want to break into pay phones or something in your spare time. I use a set of Harbor Freight Torx bits that fit 1/4" and 3/8" drives plus a set of Chapman type bits for use with a screwdriver style handle.
Re: Torx Wrenches
Railbender wrote:There is no need to get tamper proof Torx bits unless you also want to break into pay phones or something in your spare time. I use a set of Harbor Freight Torx bits that fit 1/4" and 3/8" drives plus a set of Chapman type bits for use with a screwdriver style handle.
Actuallt - the security torx bits are quite handy if you have a Garmin GPS with their mount and you misplace your "key" that Garmin provides.. DAMHIK.
Re: Torx Wrenches
I have had several instances over the years where simple repairs to home appliances required security torx wrenches.
I got my Torx set at Sears. The craftsman Torx set had all of the sizes I needed, was well made and was inexpensive.
Re: Torx Wrenches
celticus wrote:I have had several instances over the years where simple repairs to home appliances required security torx wrenches.
Mark - a FYI - the first set of security bits I purchased was from Sears. Cost was about $12 for the set. The same IDENTICAL IN EVERY WAY set is sold by Harbor Freight. On sale it's $2.99. You can be sure if it's Craftsman - but in this case - it ain't. It's made in the same Chinese factory. Sears or HF.. :)
Re: Torx Wrenches
Don, My security Torx ARE a cheapo brand but the set I usually use on my bike are Craftsman-made in The USA. :)
Re: Torx Wrenches
celticus wrote:Don, My security Torx ARE a cheapo brand but the set I usually use on my bike are Craftsman-made in The USA. :)
Bet you can't find security bits in Sears any more made in the USA.. :) Can probably find standard torx drivers.
whitelightning
Re: Torx Wrenches
Post by whitelightning »
Not cheap, but really really useful http://www.wihatools.com/300seri/366_serie_Ball.htm
Spirit Lake, ID
'05 Ducati ST3
'05 Ducati Multistrada
ShinySideUp
Re: Torx Wrenches
Post by ShinySideUp »
Barbossa
Re: Torx Wrenches
Post by Barbossa »
I use a lot of Torx.
Three sources come to mind:
1) Snap-on makes good stuff and since that's all I have, that's what I tend to go with.
2) Wiha make fantastic bits, probably the best quality anywhere.
3) You can order Torx bits on-line from McMaster-Carr. These are good quality.
Regular Torx, not Torx Plus.
