Does anyone have any ideas of where a small black rubber cap would come from? I just finished washing my bike before putting away for the winter and looked down and saw it under the front center of the bike. Looked around and couldn't figure it out. Have not figured out how to post pic on here if anyone can help I will post a pic of it.
Cap has FTE in center and 40250.003 and 40 around the outside
Scott
Help.. found rubber cap
Re: Help.. found rubber cap
That rubber cap fits over a small hole in the engine casing on the right hand side above the cylinder. It's an inspection hole for finding TDC when adjusting valves. Most of the caps fall off or get pushed inside the casing where they lay under the flywheel for hundreds of years. It's not a problem.
Thanks I appreciate it... Now the dreaded task of putting her away for the next 4-5 months.
I hope you're not talking about your wife. I did that and she divorced me!Now the dreaded task of putting her away for the next 4-5 months.
Congratulations!
-duckdave
'04 R1150R Silver
Little Rock 'n Roll
Double Lifer #580
'04 R1150R Silver
Little Rock 'n Roll
Double Lifer #580
Hi Scott, does your bike come with servo brakes? As far as I know, FTE is the manufacturer of the servo hydro unit of our bike. Parts with FTE stamping should be related to the servo hydro unit.
What is the size of the rubber plug? Does it look like a bleeder nipple rubber cap?
- harveyrawn
Mine has a rubber cap on the brake line forward of the banjo bolt on the right side of the frame at the forward edge of the gas tank. Looks like there's a grub screw under the cap.scott7024 wrote:Does anyone have any ideas of where a small black rubber cap would come from? I just finished washing my bike before putting away for the winter and looked down and saw it under the front center of the bike. Looked around and couldn't figure it out. Have not figured out how to post pic on here if anyone can help I will post a pic of it.
Scott
Harvey
Recharged on an '02
Recharged on an '02
