some for, some against things like the H4 Xenon, etc.
I'd also be curious to know if a higher wattage standard bulb is safe,
and won't melt things from too much heat.
I read on another site tonite about a Warner bulb that has 90 / 120 watts,
just standard bulb but of course would be brighter. But, too hot?
HID is out for me, too much $.
From what I've read about Xenon, I'd want a 4000 color?
Basically white.
The colored ones apparently actually cut light output with
the colored coating on the bulb. I don't care for the really
blue or purple or other colors, anyway.
Other things I've read say the Sylvania & Philips Silverstar bulbs are
good quality.
Appreciate any experience (NOT just uninformed opinions, of which
there always seem to be plenty
Thanks!
Oh, any experience with the headlight relay setup where you power
the headlight thru a relay directly off the battery (& thru a fuse of course)
and just use the switch to activate the relay, thereby supposedly getting
"full" voltage to the bulb and reducing the voltage going thru the switch?
Should be desirable (?)
