2004 R1150R Transmission lube quantity 0.85Q or 1 quart?
pclaveau
Post by pclaveau »
Hi,
Proud new owner of 2004 R1150R non ABS with 7500 on it.
Sorry but newbie question. The exisitng post related to maintenance does not clearly answer it.
The maintenance manual states "approx. 0.85 Quart or Up to fill plug" when bike on center stand.
I followed the second method and ended up filling the transmission slighly over a 1 Quart.
Calling around BMW dealers service dpt I get different answers. What do you do or recommend? #-o
Are there any risks of blowing a seal (drive shaft or main) if 1/10 of quart over or is it a none issue? Thank you!
Buckster
Donating Member #: 543
Re: 2004 R1150R Transmission lube quantity 0.85Q or 1 quart?
Post by Buckster »
Welcome to the board....I fill mine to the bottom of the threads. I've never measured the exact amount.
Buckster '03R
#543
llahbocaj
Post by llahbocaj »
You kind of can't overfill them...when you've filled up the tranny/FD it will start running down the side of your bike and dripping on the floor. For the sake of argument and so you buy enough oil to do the job it's 1 liter in the tranny and 250ml in the FD.
R4R&R
Donating Member #: 293
Post by R4R&R »
llahbocaj wrote:You kind of can't overfill them...when you've filled up the tranny/FD it will start running down the side of your bike and dripping on the floor. For the sake of argument and so you buy enough oil to do the job it's 1 liter in the tranny and 250ml in the FD.
The tranny is ok to fill until overfilled, but the final drive -you DON'T want to overfill. Only fill the final drive to the BOTTOM of the threads. Otherwise, it'll start leaking and potentially lead to other more costly repairs.
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
jm1515
Triple Lifer
Post by jm1515 »
The spec/capacity on my Maint CD says...
Capacity
initial filling l (Imp.pint/USquart) approx. 1.0 (1.76/1.06)
(to lower edge of filler screw)
oil change l (Imp.pint/USquart) approx. 0.8 (1.41/0.85)
So you can't go wrong w/ filling to the 'lower edge of filler screw'. .85 Qt = 27.2oz
Which, BTW, comes out as almost exactly 1qt (946ml) of M1 75w/140 everytime I change mine....
j magda
TripleLifer Member 454
Deep in the OH wasteland...
wncbmw
Post by wncbmw »
My manual says .85 qts and that is what I do but I usually check to see that it brings it up to the threads. Has so far. I also know this because when I did service last week, there were 3 Mobil 1 qt. jugs sitting on the shelf with .15 qt. left in them! :P I just used one of the leftovers to combine with the latest 0.15 qt leftover to fill the final drive. All the same weight and brand of course.
Vann - Lifer No. 295
pclaveau
Post by pclaveau »
Hi Gents,
Thanks for all your advice and recommendations, much appreciated and it definitely made me feel welcome to this board.
I am still learning this machine as it will become my daily commuter and I will make sure to read the different existing posts before asking questions. Thank you!
