Replacing Handlebar Grips
taosports
Post by taosports »
My heated grips need replacing after 60,000 miles. They are still producing heat...just that the rubber ribs have worn down and it looks like I may be getting close to the heating element.
Is it possible to just replace the rubber grips or do I need to replace the entire grip/heating element?
Thanks!
taosports
Re: Replacing Handlebar Grips
Post by taosports »
Never mind...found an old post by DJ Downunder...answered my question.
Thanks DJ!
http://r1150r.org/board/viewtopic.php?f ... =handlebar
jonboy59
Post by jonboy59 »
Take a hard look before you try the "solution" you found. I ruined the throttle side of my '04 by trying this. My grip had the wire moulded into the rubber of the grip with sort of a loop at the outside end. The electrical is a flat wire that I could not see a way to work past to install aftermarket grips over the heat element part.
AS Cycles has replacement grips for about $110.
Jon
taosports
Post by taosports »
Thanks for the info Jon. Since my grips need to be replaced, I have no choice but to at least try and replace them without damaging the heating element. Lot cheaper that way. Anyway, I also found the post below which will help. Let the surgery begin!
Removing grips
by circuitrider on Sat Mar 18, 2006 9:43 pm
I removed the grips on my R without damaging them. I found that the rubber is glued to the heated grip sleaves only at the ends. I removed the bar-end weights and rolled the rubber of the grip back while carefully cutting the rubber where it was glued to the sleave with a #11 exacto knife. After both ends where cut free I stuck the nozzle from my air compress under the edge of the rubber. A blast of air from the compressor expands the grip and it slips right off. Compressed air also works well for installing the new grips.
The old grips where still completely intact. I gave them to a friend to reinstall on her 1150R.
jrsndman
Donating Member #: 720
Post by jrsndman »
Removing grips
[/quote]
+ 1, using this method will make this a very easy 5 minute job!
Jim
2008 K1200GT
2002 R1150R (Black) - SOLD
2000 Suzuki Bandit 1200S
Lifer # 720
