Malfunction on the (Hibeam) head light....It whas caused of a broken WHITE main cable from the left hibeam controlunit on the stearing ...
The broken cable whas gone off in front of the petrol tank...
The cables by the steering head that are held with nylon ties have been known to brake because the ties are too tight from the factory and as the handlebars move from side to side the wires eventually break.
It is somewhat common on the early bikes, so if you have other problems look there and remove the ties for good.
Good luck
