Cylinder Head Repair
youmaycallmecasper
Post by youmaycallmecasper »
I've got the distinction of learning how well the R1200R crashes. Only real damage from my low speed down is my ego and my right cylinder head. Anyone had experience replacing the cylinder head cover?
Be curious as to the cost and the difficulty, if yoiu did it yourself.
Re: Cylinder Head Repair
I'm guessing you mean the valve cover. Replacing it takes perhaps 5 minutes. You'll need a torx wrench, and a way to remove the ignition coil. Cost? Dunno - I seem to recall replacement valve covers being around $120, but could be all wet on that.
youmaycallmecasper
Is it wet? I thought I had read somewhere the gasket was difficult.
ka5ysy
Triple Lifer
Post by ka5ysy »
Solution to the cause of the problem: #-o
MSF #127350 NAUI #36288
2011 RT
Ckaine
Post by Ckaine »
Been there/done that!!! The cost of the valve covers depends on which side. The left is more expensive then the right-oil filler. Chicago BMW has the best prices-had a 20% off list a while ago-may still have it. I believe the right was about 150 the left about 170.
Regards;
Chris
P.S. I might add the SW Motech engine guards are a good way to go-the magnesium covers are pretty easy to damage.
Chris
R1200R Black with stripes(current)
K75 Blue gone
R75/6 Gold gone
850 Norton Black/Gold Gone
youmaycallmecasper wrote:Is it wet? I thought I had read somewhere the gasket was difficult.
If you're a BMW-MOA member - I'd suggest visiting: http://www.bmwmoa.org/forum/showthread.php?t=33462 - the thread for adjusting valves. Step-1 in adjusting valves is valve cover removal. The last step is valve cover replacement. You can skip all the steps between these..
NeilS
Post by NeilS »
I just happen to have a right valve cover--with very slight rash on the lower edge--for sale. $75 delivered anywhere in USA or Canada. PM if interested or for pix.
